duckkisser Posted March 7, 2014 Report Share Posted March 7, 2014 old wood turns gray and cracks im going to use some vineger to turn my wood grey but i was wondering if there was a chemical that i could use that would allow me to make the wood crack. im making a mask and i want to be able to make the face part of the mask look like old wood. any ideas? Quote Link to comment Share on other sites More sharing options...
Tpt life Posted March 7, 2014 Report Share Posted March 7, 2014 A mask should fit in the oven. If you aren't worried about case hardening, I'd try getting it wet then forcing it dry a little faster than wise. It might be wise to try it with a scrap first. Quote Link to comment Share on other sites More sharing options...
Llama Posted March 7, 2014 Report Share Posted March 7, 2014 Not sure if this is possibleGet a piece nice and wet, and freeze it. Seems like it should crack? Quote Link to comment Share on other sites More sharing options...
duckkisser Posted March 7, 2014 Author Report Share Posted March 7, 2014 i just want to crack a small part im concerned about heat affecting the rest similar with the freezer. it has merrits but i dont know how well it would work ill try it with a small scrap where i get it wet freeze it. let it warm up and repeat. Quote Link to comment Share on other sites More sharing options...
Eric. Posted March 8, 2014 Report Share Posted March 8, 2014 I would assume baking soda would be the first choice for making wood crack. Just mix it up and cook it for a while. The first one is free. 1 Quote Link to comment Share on other sites More sharing options...
duckkisser Posted March 8, 2014 Author Report Share Posted March 8, 2014 Eric I have never heard of this how does it work how do i mix it ect.... Quote Link to comment Share on other sites More sharing options...
Tpt life Posted March 8, 2014 Report Share Posted March 8, 2014 A watched pot.... When baking, how fast does a crack develop? Can you monitor and remove at the point you get checking? Can you only wet one area to get the crack where you want it? How about a heat gun instead? Are you Edison? How many failures are you willing to try? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2014 Report Share Posted March 8, 2014 Yeah Eric i am with you. baking soda, cocaine, sawdust and you have wood crack. Quote Link to comment Share on other sites More sharing options...
Eric. Posted March 8, 2014 Report Share Posted March 8, 2014 I'm sorry, I'm being a jackass again...just ignore me. Crack...baking soda...Tyrone Biggums? No? 1 Quote Link to comment Share on other sites More sharing options...
Tpt life Posted March 8, 2014 Report Share Posted March 8, 2014 Again/Still??? 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2014 Report Share Posted March 8, 2014 no whitney houston fans here? Quote Link to comment Share on other sites More sharing options...
Llama Posted March 8, 2014 Report Share Posted March 8, 2014 Crack? Plumbers crack? Or ghetto crack? Quote Link to comment Share on other sites More sharing options...
duckkisser Posted March 8, 2014 Author Report Share Posted March 8, 2014 My head hurts from this post.....I don't realy want to carve the mask several times so I don't think I want to be like Edison. I think ill gray it but hand carve the tiny little splits and checks on the outside. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted March 8, 2014 Report Share Posted March 8, 2014 no whitney houston fans here? I'm too young. Quote Link to comment Share on other sites More sharing options...
duckkisser Posted March 8, 2014 Author Report Share Posted March 8, 2014 Doesn't baking soda just turn it grey like ebonizing solution? Won't crack it. Quote Link to comment Share on other sites More sharing options...
Eric. Posted March 8, 2014 Report Share Posted March 8, 2014 Definitely test this out first...but I'd try laying a soaking wet cloth, kind of rolled up into a worm shape, on the area you want to crack. Let it soak for a few hours. Then put it under a heat lamp. If that doesn't work, I have no other ideas. I spend all of my time trying to figure out how to make wood NOT crack. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted March 8, 2014 Report Share Posted March 8, 2014 I'd go with Eric's wet cloth suggestion. Put it in the fridge while the water is soaking in, then dry it in hot sun or under a heat lamp to get thermal shock along with fast demoisturization. If that doesn't do it, use a hammer.Excuse me...MALLET. Quote Link to comment Share on other sites More sharing options...
Tkf530 Posted March 10, 2014 Report Share Posted March 10, 2014 Make the finish crack instead of changing he actually integrity of work piece. Depending on your finish there's lacquer based "crackle lacquer" and then there's hide glue which is compatible with most finishes. Or chisel from the endgrain slowly downwards. Quote Link to comment Share on other sites More sharing options...
Janello Posted March 10, 2014 Report Share Posted March 10, 2014 I'll crack that sucka..I'll hit it with a hammer and striking chisel. If that don't work, I'll bring it to a karate tournament. And if all else fails, lay it on the train tracks. Quote Link to comment Share on other sites More sharing options...
