markpelly Posted April 10, 2014 Report Share Posted April 10, 2014 I just picked up a RIDGID Oscillating Edge/Belt Spindle Sander used and I can already see that I need to replace the paper on some. i am new to sanders, so I am unsure of what to replace the paper with. Do I need to buy and entirely new spindle with the paper on it? Or does the paper come off these and I can put a new sleeve on? Quote Link to comment Share on other sites More sharing options...
wdwerker Posted April 10, 2014 Report Share Posted April 10, 2014 I the paper won't slide off the rubber spindle try sticking it in the fridge or freezer for a few minutes. I have also used something of a smaller diameter underneath and pushed down on the abrasive to get it moving. You have to remove the spindle from the machine to get the paper off. I've had a Ridgid belt/spindle sander for years and it has held up quite well for me. Using a big vac helps but it does create a lot of dust. Quote Link to comment Share on other sites More sharing options...
Cochese Posted April 10, 2014 Report Share Posted April 10, 2014 Home Depot sells the replacement paper under the Diablo brand. I haven't replaced my paper since the Ridgid paper was discontinued, so I can't speak to how good it is. I have heard positive comments, though. Unsure if there is another source. Quote Link to comment Share on other sites More sharing options...
markpelly Posted April 10, 2014 Author Report Share Posted April 10, 2014 Is it like a roll of paper that adheres to the roller? Like a replacement disc sander paper? Or are they sleeves that fit individual spindles? Quote Link to comment Share on other sites More sharing options...
CT Proctor Posted April 10, 2014 Report Share Posted April 10, 2014 They are sleeves. Not sure about the Ridgid model but on my Jet there is a nut on top of the spindle that when turned will either expand or contract the spindle for changing the sleeves. Quote Link to comment Share on other sites More sharing options...
Llama Posted April 10, 2014 Report Share Posted April 10, 2014 I buy mine from amazon. They sell packs with different grits. I usually buy two packs at a time. Quote Link to comment Share on other sites More sharing options...
markpelly Posted April 10, 2014 Author Report Share Posted April 10, 2014 They are sleeves. Not sure about the Ridgid model but on my Jet there is a nut on top of the spindle that when turned will either expand or contract the spindle for changing the sleeves. Sounds good, thanks! I buy mine from amazon. They sell packs with different grits. I usually buy two packs at a time. I was thinking this might be a better option than grabbing them from HD. I have Amazon Prime so I am sure I can get these quickly. Quote Link to comment Share on other sites More sharing options...
Llama Posted April 10, 2014 Report Share Posted April 10, 2014 Still have to pay shipping if I recall, but it's cheap. Especially of you stock up. Quote Link to comment Share on other sites More sharing options...
markpelly Posted April 10, 2014 Author Report Share Posted April 10, 2014 Found this pack for under $12 with free shipping: http://www.amazon.com/Ridgid-AC28401-Spindle-Sandpaper-Sleeve/dp/B003XVYYI2/ $14.99 100 grit belts with free shipping: http://www.amazon.com/POWERTEC-110080-24-Inch-Aluminum-Sanding/dp/B0068AUOOI 1 Quote Link to comment Share on other sites More sharing options...
Llama Posted April 10, 2014 Report Share Posted April 10, 2014 Same guys I got mine from. Looks like they changed their policy though. Good find! Quote Link to comment Share on other sites More sharing options...
Dave H Posted April 10, 2014 Report Share Posted April 10, 2014 If you have a Harbor Freight near you they sell the sleeves for a fairly cheap price it's one of the few things I buy there and they hold up well. I also use one of those belt sander eraser cleaner thingymabobs they prolong the life of all my abrasive's. Quote Link to comment Share on other sites More sharing options...
Llama Posted April 10, 2014 Report Share Posted April 10, 2014 Those eraser things are fantastic! 1 Quote Link to comment Share on other sites More sharing options...
markpelly Posted April 10, 2014 Author Report Share Posted April 10, 2014 If you have a Harbor Freight near you they sell the sleeves for a fairly cheap price it's one of the few things I buy there and they hold up well. I also use one of those belt sander eraser cleaner thingymabobs they prolong the life of all my abrasive's. I have two Harbor Freights within 15 miles, I will have to check it out next time I am there. Yes I would definitely want one of those eraser things. Quote Link to comment Share on other sites More sharing options...
CessnaPilotBarry Posted April 10, 2014 Report Share Posted April 10, 2014 +1 on Powertec belts. I've been very happy with those and the price is excellent. I buy single grit multi-packs of sleeves from Klingspoor. Quote Link to comment Share on other sites More sharing options...
EdgewaterWW Posted April 10, 2014 Report Share Posted April 10, 2014 (edited) Klingspor from woodworkingshop.com has quality sleeves. Edit: careful with ordering the right size, check for the right sized Diameter x Length. Some sets come with 3" diameter (don't think that is a Ridgid size) Edited April 10, 2014 by Doug-EdgewaterWW Quote Link to comment Share on other sites More sharing options...
markpelly Posted April 10, 2014 Author Report Share Posted April 10, 2014 +1 on Powertec belts. I've been very happy with those and the price is excellent. I buy single grit multi-packs of sleeves from Klingspoor. Great source, thank you. Quote Link to comment Share on other sites More sharing options...
CessnaPilotBarry Posted April 11, 2014 Report Share Posted April 11, 2014 Klingspor from woodworkingshop.com has quality sleeves. Edit: careful with ordering the right size, check for the right sized Diameter x Length. Some sets come with 3" diameter (don't think that is a Ridgid size) No worries! I buy the multi-packs of a single size sleeve, in a single grit. For example, a 5 pack of 120 grit 1" diameter sleeves. Nothing I buy is unusable. One thing to keep in mind... You don't need the same range of grits in spindles you may keep on hand in flat sheets. I'm good with coarse, medium, and fine. 60 or 80, 120 or 150, and 220. If I've got a specific project that requires a lot of shaping or fine sanding, I may buy some 40 or 280 grit sleeves in the size I need, but those cases are rare. Quote Link to comment Share on other sites More sharing options...
EdgewaterWW Posted April 11, 2014 Report Share Posted April 11, 2014 Cool, I was just warning people to check the size, because 3"dia or 6"/9" Length would not fix the Ridgid. Quote Link to comment Share on other sites More sharing options...
