4 guitar build for 7 Seconds in 3,2,...1
XBIGJIMX
Well for an inaugural for the shop, I am designing and building 2 pairs of signature guitars for the band 7 Seconds, ( old punk/ hardcore band just youtube, or wikipedia them) So i got with them and asked all the fun questions of what they were looking for and wanted (as well as what they hated) . SO i drew up some designs and got there go ahead and made the start templates
928F9715-7E0C-4821-A3C0-9CF6F29EE019_zps
A79F49BB-BB4C-4887-A53B-CDECFEBEAABB_zps
Which was then transferred to 3/4 MDF using the shaper
D76202A8-4337-44BA-8179-51C069BB1031_zps
The bodies of the Basses will be walnut and the Guitars will Jatoba with maple tops SO we got the glue up of body blanks
59D29A69-5B24-402C-9AAF-1E47E8AE43C6_zps
94584520-A41F-4165-B1F9-9FD4E88C0A60_zps
Band sawed out the bodies and then off to the shaper to put the templates to use
8D01336B-B28E-4981-958F-D752817EB714_zps
Glued up some neck blanks all 5 ply 3 maple 2 walnut except one which has Jatoba. as well as a test blank 4 maple wink.png
BB70C200-0941-4BC3-B67B-ACE1AB794F58_zps
while the necks are drying will throw a round  round over on the bass bodies
1F9850E5-AB9A-4BC9-9A9E-671CC5F90CD6_zps
And let us make some fret boards . I started with slicing some Jatoba up
83C2CC07-70B6-4676-9B8E-24043E88F5AF_zps
Then a few passes though the thickness sander
5B996655-2AB1-4993-BEAA-B93318EE9EAB_zps
Fresh of the presses ...fret boards
09FCB5F8-E855-44FB-A29E-01470721AA9D_zps
After that i took the blanks out of the clamps and squared them up
299C0600-CDD5-4323-A8B7-7F228E54120B_zps
And on to the scarf joints , I cut them of at 13 degrees on the band saw. Then i made a support jig to clean ou the glue face on the jointer
BAFF862A-3787-4F9D-A128-45DD364F1B9E_zps
CF41426D-D0FC-4A01-A06C-436EAB4216E8_zps
i glued a strip of the matching wood fot a little color before gluing them up
A58E93A6-CE5B-41C6-AAD0-CF2B90574F7D_zps
After drying i cleaned up the faces and added the headstock wings
B156AF6C-E5B0-46D1-AA2C-245F59ABFDE7_zps
For the guitars we are going for a chambered body with sound holes, will this work? hellif I know but we are going to see what happens. So the out line
729FB845-29AD-499E-9EEE-F31BB971F386_zps
Hogging out the material with my helpers /intern ( my sons friend want to learn some wood working so he shows up everyday to help)
F29EC9DC-AD35-437A-AE18-C6AE3E6C8C61_zps
Oh the freaking mess, i need to get the drill press some dust control
B83004DB-A758-47BE-A06A-4EB26057DFF1_zps
Cleaning it up via the old shop smith pin router
42A26FE4-6BB6-4E9C-BECE-B18CA79731C0_zps
here is the finished route out , my intern colored outside the lines a bit if you will on the drill no mater you wont see with the top glued on
A9ADBC4A-07B1-43DE-8062-988EA6327CA9_zps
As you can see i have the neck template on there as well. I made that while he was working on hogging out the bodies
I set the start and end and put on a straight edge then went to the router and shaper to get the template
A95BA0CB-F4B8-42D6-8F82-557AC4BDFEE4_zps
Really isn't the music choice the important thing
17AEE380-9A63-46E2-A978-34B96937DE3F_zps
and safety selfie of combing your hair is over rated
19454369-25EC-463D-A103-671DB00B4FC9_zps
Well that the past weeks work for the most part to be continued
Wow, that's a lot to take in! As a guitarist wanna-be, I have long wanted to build an axe of my own, but never had the guts. You are providing some really good info, maybe enough to push me over the edge soon.
Give it a shot this is my first go at it hahah I am winging it. I just have played and teched forever so i have the concept there everything else i have learned from forums and such, measuring my guitars for refrence and guessing :)
I love this band! So awesome that you're getting to work with them on this.
They are completely fantastic people, proably some of the nicest guys I have met . I was actually blessed to fill in for Steve in 2012  when we went to Europe (I am the bass player)
I've made a couple of guitar body's by robbing the neck and electronics from other cheap guitars. They are a lot of fun and I'm just crazy enough to go over board and make a "Rat Tar" out of a 2 x 12. :)
OK, OK so it's ugly! Bet you never seen one like it before! :)
Rog
Well true believers since we last spoke this was added to the shop
CA360B67-B91B-4F31-BA8D-49B0E14932A5_zps
It is the one thing i have been drooling over since I started buying machines. Hard to tell it was used ( truth be told idont think he used it much.) So i got some bits for it 1/2 shank size ( my first 1/2 shank I feel like such an adult now) SO i got 1/2 and 3/8 straight bit. But of course it came with 4 pins....None of the 1/2 or 3/8. Well I know finding  parts would not be easy so it's off to get some round bar and turn these bad boys
ED9EEE7C-789B-4421-9D61-EE229DBA848F_zps
Also I am thoroughly convinced that Luthier is Latin for I make lots of jigs and templates. Cause I needed to route out the truss rod slots and I wanted to make it accurate and repeatable so I made a jig!
49CFCEB4-390F-4EC8-AADF-F749FC712FA2_zps
The first layer has the truss rod pin guide I wanted to be able to switch this out for different sizes (bass and guitar). The Middle layer has the center lines and holds the neck. The part with the pool ball nuts is a guide to lay the neck down fast and the then the clamps
The under side
54031CCC-63B7-42C5-8226-08B077E123F7_zps
This is it running in action
427F1AC9-4920-46A6-A4A3-5494E35231ED_zps
After that I needed to resaw the maple tops for the guitars. Now this was my first resaw and i have realized resawing is much easier with a 1" blade
079923FD-A190-4755-8698-3CC681358205_zps
C61E6559-D0D0-4B0D-BF73-9B817E45A850_zps
Then gluing up the tops
BC1F24FF-7431-4AF3-BBB4-7A2C6F19EB27_zps
Now in between all this I had to do something quiet while the grandkids were taking naps so I got my fret saw set up going. My uncle gave me his old radial arm saw when he passed. The problem is it does not have the get up and go it used to so its not good for cross cutting but it works great for fret slotting
075323F5-FEA5-46A7-96E9-7C3CB82341C5_zps
And does anybody else's outfeed table look this bad
B7DBE2CD-4BB4-4E3E-90E5-59939F3116D8_zps
A quick Sunday morning top glue up.
The spread
706CA5EB-6132-4D36-9A44-BC31E7A6E3B3_zps
Here is the first version of the body clamp, version 2 will have more cross pipes. Basiclly I use an impact to tighten the down bolt pulling the pipe into Oak cross bars making a nice joint. THis works for keeping body blanks glue ups level as well
33C31CE5-CDDC-4C39-8079-3FC0F0ECE35F_zps
Well today we worked on the bodies after pulling them out of the clamps we had the great looking model wink.png
2756B3D1-730E-48CE-8684-D01436C2E9BA_zps
After a quick trim on the band saw and a photo op with the intern
E0B74B94-25F3-4D70-A41A-6BAFC71A1A80_zps
Now off to test the pin router
768F6308-A4C1-43D2-BF60-E997BFDAFE63_zps
99D245C2-F5EA-4DF5-B881-0CD8AD354376_zps
Now cut out
1C0CD1D6-FDEB-4ABC-BB57-E03DDE5A0BE5_zps
Now i have to backtrack I totally over engineered the truss rod jig it was a little over thought. Cause i did not have a router table. I am like well let sick one on the table saw ...where is my circular saw
575066C6-7D25-4CC9-8095-8B89126FAC1A_zps
This was much easier so I got the truss rods put in
C1A027F8-5C63-4FAA-817D-B7B459AD35DE_zps
63F78DC0-A9BB-46D0-A211-CF76AE6A813F_zps
Ever have one of the those days in the shop where everything breaks ? Yep had one of those days I mean seriously how do you explode a  solid carbide bit after 20 minutes of use?
5062F289-7844-4A81-9570-97F5D60C5886_zps
That is so going back to woodcraft .
Then we had the issue of crappy 2 way tape and one shot neck blank. SO i spent the rest of the day running to wood craft and making a dozen neck blanks ( I am so not back tracking to fix screw ups, grab a new blank)
So the next day i worked on making my template for my f holes and hogging out the back control cavity. I am so not going to try to put the electronics though the f holes. When your on tour and need to do a repair no one wants to mess with that
BEB2C73B-7555-4B99-9219-FA25FFB5A2BF_zps
F832F9A1-481A-43A2-A941-20F7087D9E16_zps
Started the day routing out the f holes and cleaning up the control cavity.
9092FAE3-5434-4A41-BC3C-34A4D86E19B2_zps
Then it gets to the fun part the carve. Started with the pencil lines
14C68D2E-D809-4D93-9155-ACDFE9CB031A_zps
Went ahead and took basicly a route for a binding to knock some of the wood out and give me a finish line
A56AB6CA-CF23-453F-83B5-072B52417F7E_zps
Then with a hammer and chisel i started knocking out chunks and then used a power grinder to get it close.
20CA9536-D0E7-4E4A-BE64-1216E19A5669_zps
I then took a cabinet scraper to clean it up and some 100 grit to give it some smoothness
E3E9831D-1560-4A4E-A362-46AD9972A2C4_zps
Well in the past week have done a little of everything as usual. Had to do a rebuild of a neck  do to a slip of a template. So I ordereded some good 2 way tape so this would not be a repeat. I trimmed out on the band saw and then off to to the pin router
8AEDE868-6285-4A48-84E5-D33CA631D895_zps
Take 2 was much better by the 4th one i had it down.
Now I needed to slot fret boards next. Now with my DIY ethic would not allow me to drop the cash on the template from stew mac. So let make one.
step one get a aluminum yard stick from lowes $3
D9B59801-1EE5-4605-A201-083AA9ABBFD9_zps
I printed out the fret template (thanks internet!) and some contact cement and a file , lets get in the grove
A4AE78D8-7FDA-4F93-87D5-DEFA4DCC4C5D_zps
Now I had to make 2 shots at this the first one i went to deep with the file. I checked it to my fender jazz and it was dead on . So it works just like th estew mac ones
73F08638-FD96-4501-9A51-D54EC98D4CB9_zps
I also had to put together my fretting saw station. I had the blade since xmas and the saw was older than me and is perfect for cutting fret boards
B74CD515-14F4-474B-B5C4-A42E35CF7133_zps
th_E0273670-A842-423D-9F21-EFDC8B2DE277_
Now a little test fit after running the fret board over the shaper
C9E62B74-B99C-47E9-8F5F-D519D51AD2BE_zps
I also made a lumber run I got (from top to bottom) curly maple, spalted maple, curly maple , African Mahogany and the other pile purpleheart, paduk and purple heart. Mind you this is the most i have ever spent on lumber it kind of hurt hahahah
01674345-B818-45E8-86AF-2E74D049A821_zps
Also am i the only one who looses pencils every 3 seconds? So I had to make a stop at office depot
20086F81-E28A-4CE4-A97F-5F087C20A1CF_zps
  • 4 weeks later...
heres part 1
Well true believers it has been a few and let say i have been busy. So this what we call a photo dump with some one liners thrown in if you have any questions ask cause there is alot going on in the last few weeks. So with ...and way we go.
First off we need some fretting templates so with 3 dollar yard stick and some files
Untitled by XBIGJIMX, on Flickr
Picking a fret board
Cutting fret slots
Then off to the shaper to cut out the fret board and a test fit
Adding inlays and dots. For the dots they are a combo of brass, maple, and black resin
Next we cut the neckpocket template and the actual neck pocket
I went and cut the maple caps next to hide the long neck joint
ahh the mess
I need more clamps
A quick break where I turned a roller blade into a fret bender. cost $0
next i pressed in the frets
now heres a tip the really thin super glue will drip right through the fret slot and if you hit it with activator it will glue your finger to the fret board
  • Who's Online   2 Members, 0 Anonymous, 55 Guests (See full list)
    31.2k
    422k
    23,773
    rojmwq4e
    rojmwq4e
