4 guitar build for 7 Seconds in 3,2,...1
XBIGJIMX
Now i did a bridge mod. When I switched the pins in my acoustic to brass it made a night and day difference so i want to incorporate that into these so I added an extra route under the bridge and flattened the bottom of the bridge so the re would be more surface contact. then added a chunk of brass to the bridge
 after the pick up routes and neck attached time to shape the neck. Now I love me a good card scraper and stew mac sells the ultimate scraper that is hallow ground which is just fancy talk for a hockey skate blade behold the best scraper ever
Video in action
now along with this a carved the curves
They are completely fantastic people, proably some of the nicest guys I have met . I was actually blessed to fill in for Steve in 2012  when we went to Europe (I am the bass player)
Freakin awesome. Music is best as an aggressive physical activity. Miss my old punk days, over 20 years ago now...
Great build!
A few carve shots
Here are after some carving and smoothing
And the pick ups brass under bridge installed
Know where are those pick ups at oh yeah heres the box
checking balance
Now if you noticed there is no hole for volume or tone. Thats cause there is none. He always has issues of sweating out basses so he requested no volume and we will seal the wire holes with silicone to make them water tight. So I am usoing these bad boys as the volume sets
So after the successful test lets see if i can do it again, as luck my have it they weighed with in 1 ounce of eachother
So now back over to bobby's guitar, alot of th esteps were the same but different but it did have a few mistakes and a repair. Well before I forgot to get the final thickness down to 1.75" before the glue up and the guitar was to wide for my planner so, milled of a .25 " on the pin router which worked great on the 1st but no so much on the second
So i had to either start over or fix it so i gave it shot fixing it. I took the body to the band saw and cut it down the center. then went to the planner and took it down to 1.375". After jointing down both sides and removing a total of .25 of stock I cut a jatoba accent strip and glued it all back together. After it dryed I glued on a new bottom and ran it around the shaper using the original body as the template
after that i carved the tops with a power grinder and a scraper and glued in the necks
I fretted the fret boards before attaching this time which worked better
Now bobby requested aged hardware on of them so with some Tupperware and muric acid were off to the races. Basically you put the hard ware in a cup inside a Tupperware of muric acid and seal for about 20 minutes and boom. Mind you this is a total outside type project cause this stuff is nasty . Yes the smoke comes out of it when you poor it.
THis is the result, there is one unaged one to show the difference
While that was going i took a few shop pics to have a look around
Also I built a stewmac fretting jig. at over $400 to buy one that was not going to happen...DIY!!! total cost $35
  • 6 months later...
Ok i may very well be the worst blogger in the history of blog mania . Kind of forgot the end of the story didn't I. Well let me recap those last 5 days, For those that did not know which is none of you I made that deadline I did finish them all , mind you i was setting guitars up all night the night before i left.
Here we got them ready for finishing (except that one)all of them were grain filled then lets get tot the fun stuff ...color
Now they requested flat black which is kind of boring so I gave them one flat black the other alittle more fun temperature changing paint over some see through tops
First some serial numbers and then some coats of tung oil of the necks
Step one we rubbed in a coat of water based black
Then after a back sand to remove the black ...red
Then other 2 got the sealer
Then 2 got the flat black the other color changing paint
NExt we paint on the logos
Then some flat clear 2 part
After some curing it was wetsand then buff then alot of fret work and wiring and
The customers were really happy. The basses I stayed in tune so well many times they did an hour set an dnever needed tuning i was quite pleased now here is a few vids of happy customers
http://i167.photobucket.com/albums/u144/XBIGJIMX/th_IMG_3556_zpsutiiymkw.mp4
http://i167.photobucket.com/albums/u144/XBIGJIMX/th_IMG_3581_zpsjck4q4ji.mp4
  • Who's Online   0 Members, 0 Anonymous, 44 Guests (See full list)
    31.2k
    422.1k
    23,782
    Skillfusian
    Skillfusian
