Carrara Posted September 21, 2014 Report Share Posted September 21, 2014 Hey all, I need to cut out a piece of wood in my project and the corner radius is 25.. In the plan it says R25.. Now what diameter is R25? Is it 50mm? Have a good one! Quote Link to comment Share on other sites More sharing options...
Byrdie Posted September 21, 2014 Report Share Posted September 21, 2014 Total guess but are they indicating a 1/4" radius? Quote Link to comment Share on other sites More sharing options...
Rapid Roger Posted September 21, 2014 Report Share Posted September 21, 2014 It doesn't matter if it is R 25 MM or R .25 inches, (1/4") the radius is one half of the diameter. So if you are using millimeters,the diameter would be 50 MM. If you are using inches, the diameter would be 1/2" Or .5 inches. It is just geometry anyway. Rog Quote Link to comment Share on other sites More sharing options...
Carrara Posted September 21, 2014 Author Report Share Posted September 21, 2014 Hey guys.. In the plan all measurments are in mm but regarding the corners it just says R25 nothing more.. Quote Link to comment Share on other sites More sharing options...
..Kev Posted September 21, 2014 Report Share Posted September 21, 2014 Are you cutting a circle or rounding over an edge? Quote Link to comment Share on other sites More sharing options...
Carrara Posted September 21, 2014 Author Report Share Posted September 21, 2014 Ive got a slab of wood that I need to cut a piece sawn off in the middle of it but it should not have square corners but rounded ones and the plan says R25 Quote Link to comment Share on other sites More sharing options...
Rick A McQuay Posted September 21, 2014 Report Share Posted September 21, 2014 That is drafting notation, means 25 mm since all measurements are in mm. - sent via Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
