amateur eric Posted September 30, 2014 Report Share Posted September 30, 2014 I'm building a flag case out of purple heart wood to go on the top of a military shadow box. I know the top angle is set for 45°. What angle do I need to cut the ends of the bottom board to match up to my two sides? Quote Link to comment Share on other sites More sharing options...
Coop Posted September 30, 2014 Report Share Posted September 30, 2014 The other two angles are 45 deg. so the other 4 ends will be cut at 22.5 each Quote Link to comment Share on other sites More sharing options...
h3nry Posted September 30, 2014 Report Share Posted September 30, 2014 22.5 deg as mentioned above. But I'm confused as to why you labled these angles "67.5". It looks like the 9.5" and 15.5" dimensions only work if they are internal dimensions, so you will have to remember to cut them from pieces at least 12" long and 17" long if you're using 3/4" wood. It looks like you've only allowed 9.5" and 15.5" in your cutting diagram. Quote Link to comment Share on other sites More sharing options...
