Dnorris1369 Posted October 26, 2014 Report Share Posted October 26, 2014 Can anyone recommend where I could get some good edge banding and what kind to get. I have never used it before. I am trying to cover up some plywood ends and need something really thin. I made a boo boo building an entertainment center and have a couple exposed edges i need to fix. Thanks in advance Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
wdwerker Posted October 26, 2014 Report Share Posted October 26, 2014 Edgemate is a decent brand. Do you have any cabinet supply places in your town ? Woodworkers Supply should sell it online. When I use iron on edgeband I closely inspect the roll and try to cut around the splices. They are kinda zigzag shaped and don't always finish as nicely. Sometimes it's a challenge for really long edges. Quote Link to comment Share on other sites More sharing options...
Dnorris1369 Posted October 26, 2014 Author Report Share Posted October 26, 2014 Yea I was looking to buy it online. No places near me is edge mate iron on? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
wdwerker Posted October 26, 2014 Report Share Posted October 26, 2014 Yes, it is iron on. Woodworkers Supply carries 50 ft and 250 ft rolls . You can use a regular iron but you should practice before you try it on your entertainment center. You can trim it with an Xacto but be careful and practice first. The little tool that you squeeze and slide along the edge trims both sides at once, it's woth the investment ! When I hand apply iron on edgeband you have to move slow enough to melt the glue but not so slow you scorch the veneer. Then I use a block of wood with all the corners rounded off to rub and make sure there is real good contact. Let it cool completely before you try to trim it. Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted October 27, 2014 Report Share Posted October 27, 2014 I don't know where you live, but around here we have Menards. They carry iron on edge banding. I have used it and it works pretty well. I would recommend a specialty tool made to trim the edging. Not very expensive. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted October 27, 2014 Report Share Posted October 27, 2014 Lowes and Home Depot carry it as well. Can't say how the quality compares to what Steve suggested, but its there. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted October 27, 2014 Report Share Posted October 27, 2014 From the best to the worst its all pretty similar . Some of the better edgeband trims easier or irons down a little better. But most of those differences show up when you are using a edgeband machine. Careful hand application and sharp tools to trim will work with most edgeband. Watch out for the zig zag joints, those can be damn near invisible at times, until some stain gets on it and it looks awful ! In production finishing they behave much differently than the way most of us use stains and finishes. Like I have said many times practice and make test finish samples before you try something on a project you have a lot of time invested in ! Quote Link to comment Share on other sites More sharing options...
Freddie Posted October 27, 2014 Report Share Posted October 27, 2014 I use a sharp plane iron to flush cut my edge banding. I bought one of those trimmers from lowes a while back and its a dust collector now. If i ever find it, i will be sure to throw it out. 1 Quote Link to comment Share on other sites More sharing options...
dwacker Posted October 27, 2014 Report Share Posted October 27, 2014 Joe Woodworker or even Rockler has decent edge banding. The HD and Lowes stuff is good for starting fires but thats about it. When buying edge banding look at the side of the roll. The glue should be visible, fluffy for lack of a better word. Don't waste your time with goofy trimmers. Those trimmers were a poor alternative made back when edge banding machines spitting out miles of melamine used carbide knives. A trim router is the perfect tool for the job. The only issue is the bearing will gum up every so often and will need to be cleaned. If you don't have a trim router a single edge razor blade beat into a wooden block will work. Just beat it in at a slight angle and use the block as your guide, you do have to pry off the guard from the back edge of the razor after you beat it in. Quote Link to comment Share on other sites More sharing options...
dwacker Posted October 27, 2014 Report Share Posted October 27, 2014 This is what I mean by fluffy glue. Quote Link to comment Share on other sites More sharing options...
Michael Garrett Posted October 27, 2014 Report Share Posted October 27, 2014 Try Fastcap.com Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted October 28, 2014 Report Share Posted October 28, 2014 I guess I was just lucky. The banding trimmer I got for about $10.00 works great. It leaves just a little edge which I sand over and round off. Can't even tell it's banding. Quote Link to comment Share on other sites More sharing options...
Dnorris1369 Posted October 28, 2014 Author Report Share Posted October 28, 2014 I ordered some from rockler I was ordering some other stuff anyways so I just threw it in the cart. Guess I'll give it a try Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
