woodbutcher74 Posted November 2, 2014 Report Share Posted November 2, 2014 I sheared a roll pin on my Delta 36-714. It's on the tilt shaft. E replacement and every other tool parts place says it's no longer available, but gives no description. The last time I needed one of these I had to find one close to the right size and grind it down.What a pain. Does anyone have any ideas as to what size pin this might be? Must be metric. I tried every standard size the last time. The part number is 121246147. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted November 2, 2014 Report Share Posted November 2, 2014 Can you punch the broken pin out and check the hole diameter with a caliper? I bought a cheap plastic one that read in fractions from HF. Works great for this sort of thing, only cost about $6. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted November 2, 2014 Report Share Posted November 2, 2014 I would redrill for a standard roll pin. Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted November 2, 2014 Author Report Share Posted November 2, 2014 Thanks guys. I have punched it out once before. It's a real bite to get to without tearing the whole saw apart. I guess that's what I'll have to do. Seems like a poor design, the pin is less than 3/16" and any pressure and it shears off. Not sure if there is enough room on the gear to drill it out.I guess I'll find out. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted November 2, 2014 Report Share Posted November 2, 2014 If you can, please post a pic. I am having a difficult time envisioning why it should be shearing in the first place. Quote Link to comment Share on other sites More sharing options...
minorhero Posted November 2, 2014 Report Share Posted November 2, 2014 once you get out the remains just take it to a good hardware store (not homedepot, they won't have it) and look at their boxes for a replacement. They should have it there as delta used reasonably standard parts for that kind of thing. Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted November 2, 2014 Author Report Share Posted November 2, 2014 I tried taking the original to every hardware store around. here. Either too big or too small. Nobody carries metric. I have ordered a metric assortment from Amazon. Hopefully something will fit. Quote Link to comment Share on other sites More sharing options...
atlinwi202 Posted November 2, 2014 Report Share Posted November 2, 2014 Look online at g.l. huyett. They would have a nice selection. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted November 2, 2014 Report Share Posted November 2, 2014 I get parts from" the saw center" Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted November 3, 2014 Author Report Share Posted November 3, 2014 Thanks again for the help guys. I got my saw sort of fixed for now today.The problem is the tilt shaft turns a small worm gear that in turn meshes with a gear that rotates the blade tilt carriage. I got a new Wixey angle gauge and was trying to set the blade to a perfect zero degrees to the table. I went to .25 degrees easily and I thought I could get it to zero so I turned it a little too far and sheared the pin. Took it all a part and cleaned everything. Ground a small pin I found and got it to turn. Still can't get it to absolute zero. Checked the manual to see if there was an adjustable stop and couldn't find one. Can't detect the minute angle with my square so I guess it's as good as it's going to get. Quote Link to comment Share on other sites More sharing options...
Stampy Posted November 4, 2014 Report Share Posted November 4, 2014 You might want to try a few places north of the border for those parts. From Illinois try Toronto area. there has to be someone out there with this pin. Quote Link to comment Share on other sites More sharing options...
Coop Posted November 5, 2014 Report Share Posted November 5, 2014 Probably goes without saying but, you did look for sawdust buildup that would prevent it from going to zero? Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted November 6, 2014 Author Report Share Posted November 6, 2014 Thanks K COOPER but yeah I had it all a part cleaned it all. It looked like new. Quote Link to comment Share on other sites More sharing options...
popec Posted August 23, 2015 Report Share Posted August 23, 2015 Thanks again for the help guys. I got my saw sort of fixed for now today.The problem is the tilt shaft turns a small worm gear that in turn meshes with a gear that rotates the blade tilt carriage. I got a new Wixey angle gauge and was trying to set the blade to a perfect zero degrees to the table. I went to .25 degrees easily and I thought I could get it to zero so I turned it a little too far and sheared the pin. Took it all a part and cleaned everything. Ground a small pin I found and got it to turn. Still can't get it to absolute zero. Checked the manual to see if there was an adjustable stop and couldn't find one. Can't detect the minute angle with my square so I guess it's as good as it's going to get.To adjust the 90 & 45 degree stops on the Delta 36-714, there are two recessed set screws on the table saw top, just in front of the table insert. Should be one on the left for 90 degrees and one on the right for 45 degrees. Sadly I've broken my shear pin too and am looking for a replacement. Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted August 23, 2015 Author Report Share Posted August 23, 2015 Popec, Welcome to the dance. I finally ordered a set of metric pins from Amazon and got my saw going. I had to spend $43.00 and buy a assorted set but I've got my saw back in order. I've looked under my top and don't see the stops you are referring to. I'll have to look better the next time I have it apart. Good luck 1 Quote Link to comment Share on other sites More sharing options...
popec Posted August 27, 2015 Report Share Posted August 27, 2015 (edited) I e-mailed Delta Canada for the roll Pin dimensions for the Delta 36-714..this is the reply:The pin is 3mm X 14mm.If you broke the pin you have an issue other than that.Check the shaft and eccentric sleeve, they may be seized together so the shaft doesn’t turn freely.Remove the assembly and soak in penetrating oil to brake them loose, then clean and lubricate with lithium grease and reassemble. Regards,Delta Customer Care I suspect I broke mine, because my positive stops were slightly out of adjustment and I was forcing it against the stop--the roll pin(thankfully) being the weakest link ended up breaking, but I am going to go check my saw and make sure nothing is binding up that shouldn't be as per Delta's reply. Hope this helps anyone else out there that has sheared this pin off. @Woodbutcher74, the positive stops will be on the top surface--just little allen bolts on the top surface of your saw (see the attached photo--two holes at the bottom of the picture--the one on your left should be the 45 degree stop and the one on the right 90 degrees. ) Edited August 27, 2015 by popec added photo Quote Link to comment Share on other sites More sharing options...
Milo Posted August 27, 2015 Report Share Posted August 27, 2015 Everyone need to pay attention to what Steve said!http://www.sawcenter.com/EVERYTHING Unisaw, and they won't treat you like an idiot if you call and ask dumb questions... (says the voice of experience...) 1 Quote Link to comment Share on other sites More sharing options...
woodbutcher74 Posted August 30, 2015 Author Report Share Posted August 30, 2015 (edited) Popec, thanks for the info about the positive stops. While sorting through all my manuals, tossing the ones that I no longer own the equipment I found my table saw manual. I sure don't remember seeing that part when I set my saw up years ago. I backed my stops off and now set my blade with my Wixey. I checked the set of roll pins the I've got 10- 3mm x18mm. I'd be glad to mail you a couple if you still need one. Now that I have my saw adjusted I don't think I'll be breaking anymore. Let me know. Edited August 30, 2015 by woodbutcher74 Quote Link to comment Share on other sites More sharing options...
