Router Bit Storage Cabinet
Megashed
I recently got a couple of plywood router bits and realized my amount of singles are catching up on me. I decided to build a storage cabinet and found a plan I liked on the net. I made some changes, a little deeper to allow for a french cleat, and some adjustments to the bit shelves to allow for my larger panel cutter bits. The cabinet is maple. I got the carcass lumber milled and assembled last saturday.
post-7010-0-56930400-1414890782_thumb.jp
post-7010-0-76611200-1414892659_thumb.jp
I had to glue up two pieces of 3/4" to get to the 1.5" needed for the shelves... thinking its time to get more clamps.
post-7010-0-16651700-1414891481_thumb.jp
I made two bottom drawers out of mdf, this was my first kick at using a drawer lock bit, obviously my setup could use some work, but for a shop cabinet it should be fine.
post-7010-0-68457700-1414891759_thumb.jp
Next I milled up the bit shelves
post-7010-0-18264600-1414891880_thumb.jp
Then onto the holes. I made the two top shelves on each tier for 1/4" bits. I made a small counter sink for a 1/2" at every hole to make it easy if I ever want to widen them out.
post-7010-0-78347600-1414892201_thumb.jp
And more holes...
post-7010-0-55305500-1414892252_thumb.jp
Putting the bit shelves together, a 20 degree angle on the backs will give the shelves a nice forward tilt.
post-7010-0-82341200-1414892464_thumb.jp
Starting to come together, next weekend I plan to built a door using some acrylic for the "glass"
post-7010-0-90047000-1414892620_thumb.jp
post-7010-0-61344100-1414892574_thumb.jp
Boy, it puts what I did to shame... I built ten drawers for my router table put a 6/4 10"x17" slab of EWP in each and drilled a matrix of 1/2", 8mm and 1/4" holes... I thought it was top-shelf, then I saw that last photo or two of your storage rack... You've raised the bar... From one ODC sufferer to another - Congrats... But, you know what's really going to hurt... That 121st bit... So Enjoy... For now... :)
I'm picking up what your laying down Chef. I've thought about the need for labels, not really a need, but handy for some rabbiting bits and such. I have access to a p-touch label maker through work, so I'm planning on labeling certain parking spots that way. Can you post a photo of your storage?
I will get you a photo as soon as I get some more stuff moved out of the way.
I did not make it to that corner of the shop to get a picture today. I did find a similar picture of what Paul had done. I believe that it is from Wood mag.
http://www.woodmagazine.com/woodworking-tips/techniques/skills/drilling-tips/?catref=wd146&page=1
http://images.meredith.com/wood/images/2010/02/ss_bitHolder.jpg
Paul took it a step farther. He cut a 1" profile of each bit and glued it onto the front of the shelf that holds the bits. Even I can get the bit back to the proper location. He used left overs from the projects that he used the bit for. Each of the profiles are in different woods.
  • Who's Online   1 Member, 0 Anonymous, 33 Guests (See full list)
    31.2k
    422k
    23,773
    rojmwq4e
    rojmwq4e
