kayakfish Posted February 10, 2015 Report Share Posted February 10, 2015 Hello I am new to the finishes that are safe for animals and humans alike. I am building a Hatcher for my chicken eggs and using Maple Cabinet Grade Plywood to build it. I know I can finish the outside with no issues but I need a finish on the inside that wont have fumes that make my baby chicks sick or die. I also want to use a finish that will be able to handle 100 degree heat with humidity of 50% - 75%, and be able to sanitize it after each hatch. I was told by a few folks that I can use the MinWax Polyacrylic inside with no issues is this true? Quote Link to comment Share on other sites More sharing options...
mikem Posted February 10, 2015 Report Share Posted February 10, 2015 For animals, I think I would leave it raw. 1 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 10, 2015 Report Share Posted February 10, 2015 I would check with your county extension agent or the Agriculture department. I built a hatchery / display area for a Agriculture fair years ago. I remember we painted it white inside and out. Pretty sure I used a waterbourne finish. If you don't find a definitive answer I would finish w a water bourne , let it sit and cure for several days at temperature then clean it before you put eggs/ chicks in it. Quote Link to comment Share on other sites More sharing options...
