marc ta Posted March 23, 2015 Report Share Posted March 23, 2015 I am to refinish a very large table (6'x15') which was originally finished with a post-catalyzed lacquer. I cannot use a spray finish because of location constraints (people working in nearby room, no adequate ventilation possible, etc.). Also, I cannot strip the table to bare wood because the tabletop is a thin veneer. It has been cleaned with TSP, sanded with 400 grit and wiped with liquid sandpaper. I tried to roll a waterbased floor polyurethane (Saman Extreme), but it peels off pretty easy and there were lots of fish eyes. I've just learned about applying dewaxed shellac first to prevent fish eyes (thanks to this forum), but I am still a little hesitant about recoating with the waterbased poly. Any recommendations as to what finish will stand the test of time? Perhaps an oil-based poly (Helmsman spar urethane) or a brushing lacquer? Airborne dust particles landing on the tabletop are also a concern. Thats why I used the waterbase poly to begin with; because it dries fairly quickly. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted March 23, 2015 Report Share Posted March 23, 2015 You are way outside my comfort zone. I would be on the phone with my finish supplier and see if he has a recommendation . I don't think consumer grade finishes will be appropriate . Quote Link to comment Share on other sites More sharing options...
dwacker Posted March 23, 2015 Report Share Posted March 23, 2015 Nope. Once it cured you can't finish over catalyzed lacquer even with the same lacquer. Once its catalyzed it has good chemical resistance. Quote Link to comment Share on other sites More sharing options...
marc ta Posted March 24, 2015 Author Report Share Posted March 24, 2015 Thanks for the tip. I've managed to peel off the waterborne poly today without damaging the lacquer finish. phew. I've heard about using dewaxed shellac on the table first to seal, then proceed with whatever finish Quote Link to comment Share on other sites More sharing options...
