Willin Posted May 26, 2015 Report Share Posted May 26, 2015 If you have upgraded using the $180 Carter b.b. guides, I would like to hear how they enable more precise resawing. If you have upgraded using the ~$60 Incredible guide, likewise. How does it enhance resaw ability. I see that the Incredible, available only through an eBay store, is only a top set. Bottom guide remains stock. I do not have the riser block on my Delta, and do not want it. Am happy with the resaw height I have, but just want some more precision. I have Cool Blocks and a good 3/4" blade as my only upgrades. Quote Link to comment Share on other sites More sharing options...
AceHoleInOne Posted May 26, 2015 Report Share Posted May 26, 2015 I have used cool blocks.....ummm....didn't think they were all that great. Put the stock steel guides back in my Delta, and back to being a happy camper. I get perfect re-saw results. I do have a riser block. Good blade and a proper saw set-up you should be fine......I say keep the money for other shop requirements. -Ace- Quote Link to comment Share on other sites More sharing options...
ColinF Posted May 28, 2015 Report Share Posted May 28, 2015 My masterforce 14" has all roller bearing guides, I had a delta with blocks, honestly, if your blade is set up right, and your not forcing your work, you shouldn't have to worry about drift. I set my fence square to the table and get nice straight cuts. I think it's more about feed pressure and blade tension than guides. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted May 28, 2015 Report Share Posted May 28, 2015 I have had the Carter ball bearing set on my Delta for years and they made a night and day difference for me. So easy to adjust and I find I break fewer blades too. I also replaced the tension spring and the crank handle with an extended one. Quote Link to comment Share on other sites More sharing options...
