Grasslakedoc Posted July 15, 2015 Report Share Posted July 15, 2015 I have a 5 inch random orbit sander and am looking to go for a high-gloss lacquer finish. I see one way is to use 1000+ grit sand paper, and inherited a pack of 6" Abrasion discs. Will I get good results from using the 6" or should I spring for the 5" online? Thanks much in advance. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted July 15, 2015 Report Share Posted July 15, 2015 You could try trimming one down and see how that works. I would be afraid of the unsupported material tearing and leaving marks. Quote Link to comment Share on other sites More sharing options...
Tom King Posted July 15, 2015 Report Share Posted July 15, 2015 It'll sharpen a pair of scissors used for trimming it. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted July 16, 2015 Report Share Posted July 16, 2015 Do the disks have holes for vacuum dust removal? They probably won't line up, but it isn't a deal breaker. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted July 16, 2015 Report Share Posted July 16, 2015 Abrasion discs or Abralon ( similar to ScotchBrite) Quote Link to comment Share on other sites More sharing options...
Boatworks Today Posted July 18, 2015 Report Share Posted July 18, 2015 Depending on the sander it may not make much of a difference. The key is maintaining a random orbit with a rotary action. If the sanding pad gets dogged down and no longer maintains a rotary action tour going to be left with deep pigtails. If the pad keeps rotating with the random orbit then you'll get a clean sanding action. If it dogs down, lighten the downward pressure. Worst case is you use the sander for the bulk work and finish up by hand to get a more uniform scratch pattern :-) Quote Link to comment Share on other sites More sharing options...
