my first project
mitchboudeman
This is my first wood project and I didn't start off too simple. My girlfriend requested a coffee table for her birthday and I figured it could be pretty simple. But then I started looking at pictures online andd got a little ahead of myself. So after a lot of learning and a few months I finally finished. It's 4 feet by 2.5 feet made out of walnut, ash, European red oak, african purple heart, and poplar. It also has a bartop epoxy on top
You certainly didn't start off simple!  Super nice job on the finish!  What joinery did you use for the base and how did you attach the top?
I built the base first and I used mostly screwed and glued butt joints. Then for the top I screwed a piece of half inch plywood the same size as the top onto the base. Then I put the top directly onto that with glue and screws from under the plywood. Finally I put a veneer on the bottom of the plywood so all screws are hidden and put the trim around the outside.
