jds Posted August 29, 2015 Report Share Posted August 29, 2015 What bit would you recommend for using the Festool MFK 700 router to trim solid wood banding. Is is there one that would work for banding up to ¾"? Quote Link to comment Share on other sites More sharing options...
Trip Posted August 29, 2015 Report Share Posted August 29, 2015 I purchased a 700 around the time it was released. At the time, the big drawback to the 700 was incompatibility with non-FT bits. The largest edge-trimming bit at the time was FT’s 491666. Also at the time, there was no bit that could trim ¾ edging. I believe there is still no off-the-shelf solution.There are several WTO members who have modified the base to permit longer bits. If you search the WTO archive, you’ll find references to the mods...If you find a solution, please post it as there would be interest. Quote Link to comment Share on other sites More sharing options...
