Fxguy Posted September 28, 2015 Report Share Posted September 28, 2015 Hello everyone! So for my first big project I decided to build my kids a rocking horse. The rockers and platform are made of maple, the rest of cherry. I cut the rockers out a little over size, then clamped them together and trimmed them up on the bandsaw. Then as I started to sand them down, I noticed that they are a little rounded crosswise. So what would be the best way to square them the length of the rocker curve? Thanks!! Quote Link to comment Share on other sites More sharing options...
davewyo Posted September 28, 2015 Report Share Posted September 28, 2015 (edited) You could possibly make a template traced from the rockers, double stick tape it to the rocker, and then use a flush trim bit in a hand held router or on a router table. Edited September 28, 2015 by davewyo 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted September 28, 2015 Report Share Posted September 28, 2015 What Dave said, but on the bottom edge, don't you want them rounded anyway? Quote Link to comment Share on other sites More sharing options...
Fxguy Posted September 28, 2015 Author Report Share Posted September 28, 2015 ? they are rounded lengthwise, but also crosswise, kind of like a hockey skate. So there is a bit of a ridge down the center of the rocker Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Immortan D Posted September 28, 2015 Report Share Posted September 28, 2015 Once you established what needs to be removed (the hard part) you can use hand planes. Quote Link to comment Share on other sites More sharing options...
Andy Wright Posted September 28, 2015 Report Share Posted September 28, 2015 I would second the suggestion of making a template and then trimming them with a router/router table. I always make my templates out of MDF because it is so easy to fine tune the shape with a file and sandpaper. Quote Link to comment Share on other sites More sharing options...
krtwood Posted September 29, 2015 Report Share Posted September 29, 2015 How rounded are we talking here? You created the rounding with sanding, you can fix it with sanding. Clamp the two together and use a sanding block or sandpaper glued to a larger flat surface. A little bit of rounding isn't a big deal. Quote Link to comment Share on other sites More sharing options...
