namluke Posted November 27, 2015 Report Share Posted November 27, 2015 Hi im looking for a good pilot hole with countersink combined.I purchased the below one but didn't think much of it.The bit wobbles and easily comes out.Can someone recommend one that is trust worthy? http://www.amazon.co.uk/DeWalt-DEWDT7612XJ-Flip-Drive-Set/dp/B000Y8VQ6A/ref=sr_1_11?s=diy&ie=UTF8&qid=1448653551&sr=1-11&keywords=dewalt+pilot+drill+bitsMany Thanks Luke Quote Link to comment Share on other sites More sharing options...
..Kev Posted November 27, 2015 Report Share Posted November 27, 2015 I've been using these and had good luck with them..http://www.rockler.com/rockler-3-piece-tapered-countersink-bit-set-with-case 2 Quote Link to comment Share on other sites More sharing options...
namluke Posted November 27, 2015 Author Report Share Posted November 27, 2015 Thank you for your reply. Thats what ive been looking for. Quote Link to comment Share on other sites More sharing options...
d8nk Posted November 27, 2015 Report Share Posted November 27, 2015 I've been using these and had good luck with them..http://www.rockler.com/rockler-3-piece-tapered-countersink-bit-set-with-case This is exactly what I use and would recommend as well! Quote Link to comment Share on other sites More sharing options...
Immortan D Posted November 27, 2015 Report Share Posted November 27, 2015 I use dedicated countersink bits from Bosch.I have this cheap set of combined countersink bits, but I don't recommend them because they have the same problem your set has, the bits come lose when the drill stops spinning, so I have to tighten them again before starting a new hole. A PITA. Quote Link to comment Share on other sites More sharing options...
Trip Posted November 27, 2015 Report Share Posted November 27, 2015 (edited) ==>for a good pilot hole with countersink combinedThese are what I use: http://wlfuller.com/html/type__c__sets.htmlThey are very good quality, made in Road Island and not exactly cheap... But I've got several sets and none have been duds... This is the most purchased and my goto:http://wlfuller.com/html/no__11_set.html I've got both of their large sets, which are great, but a bit more costly... They are parabolic and therefore reside at the drill press: http://wlfuller.com/html/taper_point_drills.html Edited November 27, 2015 by hhh Quote Link to comment Share on other sites More sharing options...
TerryMcK Posted November 27, 2015 Report Share Posted November 27, 2015 i have the Dewalt set and it is really good - the bit doesn't wobble on mine. You must have the drill positioned incorrectly so the grub screw is tightening on a flute rather than the flat on the shaft of the drill. Quote Link to comment Share on other sites More sharing options...
Cochese Posted November 27, 2015 Report Share Posted November 27, 2015 I use the Insty ones from Rockler. Highly recommended. Quote Link to comment Share on other sites More sharing options...
Alan Bienlein Posted November 27, 2015 Report Share Posted November 27, 2015 I've tried just about all the ones listed and the only one for me is the Jack Rabbit.http://www.jackrabbittool.com/ Quote Link to comment Share on other sites More sharing options...
Cliff Posted November 27, 2015 Report Share Posted November 27, 2015 I use dedicated countersink bits from Bosch.I have this cheap set of combined countersink bits, but I don't recommend them because they have the same problem your set has, the bits come lose when the drill stops spinning, so I have to tighten them again before starting a new hole. A PITA.Those are what I have as well. I don't even bother to use them. Quote Link to comment Share on other sites More sharing options...
