Draw knife beginner questions
superman911_usmc
So I just got a draw knife and I'm learning to use it.  I have an issue I'm running into.  On the same piece of lumber some places it's shaving like butter and other parts it's splintering badly.  What would cause this?  Am I doing something wrong or is it the wood?  I'm pretty sure it's hard maple if that helps.  Thanks for your time!
Hickory will have a coarser grain and more darker streaks. Hard maple will vary in color but it has a much finer grain
Could be the knife isn't sharp enough , just a possibility . As soon as you see tear out try cutting from the opposite direction . Some areas of grain will behave better if you make shearing diagonal cuts, varying the angle you are holding the knife. Practicing on scraps is a great way to learn what works for you before you mess up on the pieces needed for your project.
With experience you will learn that careful stock selection will produce better results. Keep your eye out for the grain patterns that caused your tear outs and avoid choosing those.
I would think that you would want clear straight grain for a bow. Wether or not a naturally curved piece is good for making a bow the grain still can be straight and clear of swirls and knots.
