jgfore Posted December 29, 2010 Report Share Posted December 29, 2010 I purchased the Porter Cable 12" Dovetail jig tonight. Got it home and found out that the jig collar (templet guide) does not fit my Bosch 1617 router. I have checked several different places to see what is sold to fix the problem. What I have found is the Quick adapter (RA1126) and the 7 peice set of Bosch templet guides would do the job (RA1126), but before I spend another $60.00 on top of what I have already spent, I thought that I would see if anyone else has ran into the problem. If so, how did you handle the problem? Jeff F Quote Link to comment Share on other sites More sharing options...
PaulMarcel Posted December 29, 2010 Report Share Posted December 29, 2010 I had that problem, too, with the 1617 and the Leigh D4R jig. I found an adapter that snaps into the 1617 like those Bosch-specific quick-change guides, but it accepts regular "de facto" Porter-Cable templet guides (the 2-part guides). I have the piece in front of me and there's no part number on it. A quick search found that what I have is a RA1100. Here's a link to the RA1100 at International Tools. (I've never used them; but that's a listing I found). Here's the information on the RA1100 from Bosch. That page states you need the RA1126, which isn't too expensive. Check your router, though, as I had the RA1126 in the kit I bought. Worse case, it's about $14 total at International Tools; I believe Amazon had them, too. Quote Link to comment Share on other sites More sharing options...
jgfore Posted December 29, 2010 Author Report Share Posted December 29, 2010 I had that problem, too, with the 1617 and the Leigh D4R jig. I found an adapter that snaps into the 1617 like those Bosch-specific quick-change guides, but it accepts regular "de facto" Porter-Cable templet guides (the 2-part guides). I have the piece in front of me and there's no part number on it. A quick search found that what I have is a RA1100. Here's a link to the RA1100 at International Tools. (I've never used them; but that's a listing I found). Here's the information on the RA1100 from Bosch. That page states you need the RA1126, which isn't too expensive. Check your router, though, as I had the RA1126 in the kit I bought. Worse case, it's about $14 total at International Tools; I believe Amazon had them, too. Thanks Paul. I was looking at those as well. I also found a router base plate at Woodcraft, Link. Picture below. I think this is the same type of base plate the Marc used with the Halloween blow video while using the template. Do you know how this would work? Jeff Quote Link to comment Share on other sites More sharing options...
WoodClips Posted December 29, 2010 Report Share Posted December 29, 2010 The adapter is also available on Amazon.com for $5.08 with free shipping if you order $25 or more. I've been using Porter Cable guides with the adapter and my experience is that you really need to tighten up the nut or it will loosen while you are using it, but then it is a real pain to get off because there isn't a good way to grip the guide to keep it from turning while you loosen the nut. So, I'd consider buying the Bosch template guide set for $27 so you don't have to mess around with the adapter. If you are only using the one bushing for your dovetail jig it may not be a problem, but if you are switching between different sizes, I think buying the Bosch guides is the way to go. Rory Quote Link to comment Share on other sites More sharing options...
Mike M Posted December 29, 2010 Report Share Posted December 29, 2010 I have the Bosch 1617 too and tried the Bosch adapter. It worked, but it totally blocked sight through the base which I found that annoying. I ended up making a base out of clear acrylic similar to the one in Jeff's picture and have been using it to hold the PC guides. The guides that came with my PC jig included a couple of 'O' rings that go between the guide and the knurled nut. This makes tightening the nut less critical because it won't vibrate loose and also makes it easier to get the nut off. The problem is then taking the 'O' ring off. I solved that problem by looping some sewing thread around the ring before I installed it. I can the grab the loop of thread and pull the ring off. Quote Link to comment Share on other sites More sharing options...
jab73180 Posted December 29, 2010 Report Share Posted December 29, 2010 I have the bosch guide set and I think it works well. The only thing is don't forget toget some sort of centering cone. You have to center the base plate to the collar. I think I got mine on amazon. Remember to use the TWW amazon store so marc gets credit. Quote Link to comment Share on other sites More sharing options...
mikem Posted December 29, 2010 Report Share Posted December 29, 2010 I have the bosch with the woodcraft adapter that you pictured. Works great! -- The other MikeM Quote Link to comment Share on other sites More sharing options...
jgfore Posted December 30, 2010 Author Report Share Posted December 30, 2010 I ended up purchasing the Bosch quick connector and the Bosch template guid set. When it gets here, I will post my results. Quote Link to comment Share on other sites More sharing options...
Green Head Posted January 3, 2011 Report Share Posted January 3, 2011 Can I get a little clarification? Do you need the RA1100 and the RA1126 to accept PC guide bushings? Or, can you get by with just the RA1100? Thanks Quote Link to comment Share on other sites More sharing options...
WoodClips Posted January 4, 2011 Report Share Posted January 4, 2011 Can I get a little clarification? Do you need the RA1100 and the RA1126 to accept PC guide bushings? Or, can you get by with just the RA1100? You will need both. The RA1126 mounts to the router base and accepts either the Bosch template guides or the RA1100 adapter for the Porter Cable guides. Double-check that you don't already have the 1126 before you buy one though--mine came with the router kit. Rory Quote Link to comment Share on other sites More sharing options...
KenBee Posted August 21, 2011 Report Share Posted August 21, 2011 For those having a problem loosening or tightening the template guide nut go to your local hardware store and buy a set of plumbers pliers with the rubber jaw inserts. I have a set of Ridgid template guides that came with two base plates. One for the Ridgid router and one that can be drilled to fit any router and use the template guides.Most woodworkers do not like the Ridgid guides because they are steel and reputedly vibrate loose unlike brass guides. I got some sad news for those Nay Sayers. I have never had one vibrate loose after dozens of applications. I also have a PC base plate I re-drilled to use with my Hitachi router for use on my PC 4216 DT jig. Quote Link to comment Share on other sites More sharing options...
