jocko2 Posted July 3, 2016 Report Share Posted July 3, 2016 Was wondering if I can polyurethane (oil based) over an IKEA counter top that is oil treated from the factory. I want to use the counter top as a desk top for a computer / homework desk. Going out on a limb I would think that maybe the factory oil treatment is linseed oil based as that is what IKEA's wood treatment in the can that they recommend for maintenance on this item is. the link to the wood counter top is below, http://www.ikea.com/ca/en/catalog/products/40274960/#/80274963 any thoughts or suggestions would be super appreciated. Jocko Quote Link to comment Share on other sites More sharing options...
JosephThomas Posted July 3, 2016 Report Share Posted July 3, 2016 No idea what ikea uses....Ideally you'd sand it down to bare wood. If you're hoping to avoid that, you're gonna wanna test whatever you do on the underside in a small area and give it a couple days to cure and see how it does. I think if you do a coat of shellac first, you'll probably have good luck with any varnish you want on top of that. Quote Link to comment Share on other sites More sharing options...
RichardA Posted July 3, 2016 Report Share Posted July 3, 2016 If it's already dry, you can use an oil based polyurethane! Put at least 3 coats, sanding with 220 grit lightly between each coat! Then buff with #0000 steel wool, wipe it clean, then a wax finish! All you'll have to do after that is re wax every few months! Quote Link to comment Share on other sites More sharing options...
wdwerker Posted July 3, 2016 Report Share Posted July 3, 2016 All good reccomendations above. Fine sanding, testing on the bottom, de waxed shellac as a barrier seal coat then polyurethane will work just fine. 1 Quote Link to comment Share on other sites More sharing options...
