Popular Post Llama Posted July 18, 2016 Popular Post Report Share Posted July 18, 2016 Most of you know I am building one of these things.. So, I figure it's best to put the pics on one place. Since I started playing again, I decided to resurrect this thing. It is not so loosely based on a Ritter Roya, and the wood is cherry. Pickup layout: Rough routed. Pots located, holes drilled: More freaking layout: I made some templates for this. And the first mistake should be obvious. It's an easy fix, so not worried about it: A la Ritter. I will be making a wooden cavity cover for this: Mistake!!! Due to my desire to sculpt the sides more than Ritter does, this is what happened. Little blow out. I have a fix in mind, again not worried about it. 5 Quote Link to comment Share on other sites More sharing options...
Gary Posted July 18, 2016 Report Share Posted July 18, 2016 Cool Mel! Looking forward to this. I love Ritter's stuff and admire the fact that his instruments are true art pieces. 1 Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted July 18, 2016 Report Share Posted July 18, 2016 Mel, did you just start this project or was it something you put on hold? Either way, it looks like you are off to a great start. I really like the bodies shape. Quote Link to comment Share on other sites More sharing options...
Tom Cancelleri Posted July 18, 2016 Report Share Posted July 18, 2016 One thing I never really understood when it came to basses like that is the top horn. The grain direction leaves it more susceptible to breaking, especially with the addition of a strap mounting there. My thoughts would be to drill a 3/8" hole down the horn towards the body (in the center of course), some glue and a cherry dowel, and then cover the dowel the the strap button. Quote Link to comment Share on other sites More sharing options...
Llama Posted July 18, 2016 Author Report Share Posted July 18, 2016 15 minutes ago, Woodenskye said: put on hold This one... I shaped the body several years ago, and it just sat on the shelf. 8 minutes ago, Tom Cancelleri said: top horn Haven't seen any break at that point unless they really get banged. The wood is right around 1.75" (44.45mm for the Canadian), so I'm really not concerned with that being an issue. 3 hours ago, Gary said: Looking forward to this. thanks Me too lol... It's been a long time in the making! Quote Link to comment Share on other sites More sharing options...
Gary Posted July 18, 2016 Report Share Posted July 18, 2016 2 hours ago, Llama said: Haven't seen any break at that point unless they really get banged. The wood is right around 1.75" (44.45mm for the Canadian), so I'm really not concerned with that being an issue. If you're not breaking the top horn, you're not rocking hard enough! 1 Quote Link to comment Share on other sites More sharing options...
davewyo Posted July 18, 2016 Report Share Posted July 18, 2016 6 hours ago, Llama said: Most of you know I am building one of these things.. So, I figure it's best to put the pics on one place. Since I started playing again, I decided to resurrect this thing. It is not so loosely based on a Ritter Roya, and the wood is cherry. Pickup layout: Rough routed. Pots located, holes drilled: More freaking layout: I made some templates for this. And the first mistake should be obvious. It's an easy fix, so not worried about it: A la Ritter. I will be making a wooden cavity cover for this: Mistake!!! Due to my desire to sculpt the sides more than Ritter does, this is what happened. Little blow out. I have a fix in mind, again not worried about it. Cool! Another musical instrument thread. I love the jigging, templating and the clamping strategies youze guys get up to when you make these things. While the second mistake is glaringly obvious, and it will be interesting to see the fix you have in mind, I don't see the first mistake. Of course I don't know what you should be doing so it's difficult to know when you do something "off". Do tell... Quote Link to comment Share on other sites More sharing options...
shaneymack Posted July 18, 2016 Report Share Posted July 18, 2016 This is looking cool Mel ! Sent from my SM-N910W8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Llama Posted July 18, 2016 Author Report Share Posted July 18, 2016 55 minutes ago, davewyo said: Do tell... Due to the layout of the control cavity, I had to route into where one of the pickups mount. I'll have to add a piece of wood there for the screw to attach. Quote Link to comment Share on other sites More sharing options...
davewyo Posted July 19, 2016 Report Share Posted July 19, 2016 Oh! I see! That little round spot you marked out during the "more freakin' layout" part. Quote Link to comment Share on other sites More sharing options...
..Kev Posted July 19, 2016 Report Share Posted July 19, 2016 Good to see you going on this again Mel! Quote Link to comment Share on other sites More sharing options...
