MisterDrow Posted July 20, 2016 Report Share Posted July 20, 2016 I'm admitting my own inexperience here... Making some test boxes to see what works best for some tabletop game deck boxes. I'd like to use 1/4" solid wood and plan on rabbeting the top and bottom but when it comes to the sides, is 1/4" enough for a miter joint? I know plain miters aren't very strong, typically, but I'm hoping that having the top and bottom put on with rabbets will help to give it strength. The smallest boxes will be roughly 3" x 3.25" and roughly 4" tall. My initial thought was splines but on 1/4" stock, it doesn't seem like that would add much. Thoughts? Maybe I need to consider doing 3/8" instead unless I use plywood? I'm going to be messing around with some options tonight and would love some input/tips from those who know better. Quote Link to comment Share on other sites More sharing options...
Popular Post wdwerker Posted July 20, 2016 Popular Post Report Share Posted July 20, 2016 Finger or box joints would work well. 3 Quote Link to comment Share on other sites More sharing options...
MisterDrow Posted July 20, 2016 Author Report Share Posted July 20, 2016 Yeah... I just need to break down and build a box joint jig. I still don't have a dado stack and haven't had very good luck in the past getting box joints to work out well. I know it can be done, however, and with a jig maybe I'll have better results? On the boxes I don't want to show end-grain, I'm assuming miters would be my only real option. Maybe given the utility of such a small box and the fact that the boxes aren't going to be under a lot of pressure/stress then the miters would be enough? Quote Link to comment Share on other sites More sharing options...
wdwerker Posted July 20, 2016 Report Share Posted July 20, 2016 Miters can work if they are cut extremely accurate. There is a Brittish box maker on another site that does miter fold boxes from thin wood and veneers . I think he uses a router with a "vee" bit and tape on the outside to act as a hinge. search for BritBoxmaker Quote Link to comment Share on other sites More sharing options...
MisterDrow Posted July 20, 2016 Author Report Share Posted July 20, 2016 Huh... a vee bit sounds like an excellent way to do it, tbh... I'll check that out. Thanks! Quote Link to comment Share on other sites More sharing options...
Eric. Posted July 20, 2016 Report Share Posted July 20, 2016 For little tiny boxes like that with such thin stock, I'd use miters for sure. I wouldn't even reinforce them. I'd glue them up using packing tape as clamps. I think Marc used that trick in this ancient video... 1 Quote Link to comment Share on other sites More sharing options...
Barron Posted July 20, 2016 Report Share Posted July 20, 2016 I agree with Eric, which always worries me, that miters will be plenty strong. If you use plywood for the bottoms you can glue them to the sides for added strength. You can use splines for extra strength and for looks. Even with solid wood top/bottom wood movement won't be much of an issue on boxes that small. One other thing to make miters stronger is to paint the mitered ends with some thinned glue, let it sit 4-5 minutes then apply full strength glue and use tape and/or rubber bands to clamps it together. On small boxes thin sides look better, in my opinion. 1 Quote Link to comment Share on other sites More sharing options...
Coop Posted July 21, 2016 Report Share Posted July 21, 2016 I too often use splines on mine, albeit, the can't be very deep with 1/4" wood. 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted July 21, 2016 Report Share Posted July 21, 2016 I did a journal last year, called "A bunch o' boxes". Some of them are 1/4" material, all joints mitered, no reinforcement. One is currently serving as my 'valet' box to dump my pockets into every night. Holding up fine thus far! 1 Quote Link to comment Share on other sites More sharing options...
