2-Piece Edge Banding Bit Sets
NJ_Mike
Anyone have experience with these or this type of bit?
http://www.eagleamerica.com/product/vp16-4041/pc_-_glue_joints
or
https://www.amazon.com/Yonico-15223-Matched-Tongue-Banding/dp/B00KZM2AII/ref=cm_cr_arp_d_product_sims?ie=UTF8
i'm about to start building a tv stand and want to cover the plywood edges.  Are these just a hassle or they worth it?  I have 0 experience with this type of bit.  Opinions welcome.
Thanks
I might get some push back on this but when glue and blue tape won't keep edgebanding aligned I use a 23 gauge headless micro pin at a slight angle. The hole is so small they fill with sanding dust. And they can be had quite cheaply. The one HF sells is around $25 and shoots up to a 1" pin. One survived 2 years of abuse and fired over 13500 pins. It's just a backup now but it still works. I have one by Grex that shoots up to 2" pins but that one cost 12 times more !
1/4" to 3/8" thick edgeband works fine. I wouldn't make it much thinner than 1/8" but thinner is easier to cut flush and sand smooth.
Whiteside makes those for Eagle America.  I expect the reason they are on sale is because hardly anyone uses them.  I just leave the banding a little proud, and finish with a super sharp block plane.  I know there are some here that are 40 years old, and haven't fallen off yet.
