Paddy Posted August 24, 2016 Report Share Posted August 24, 2016 Hi Guys I've been working on an outside table. I've finished the legs (Pine) using Danish oil but the wife isn't a fan and has decided that painting the legs with a Gloss Dark oak would be nicer. I've done a bit of research and the best I can see I can find is that I should do the following: Rub down with white spirit Sand lightly (220 grit) Do you think that would work? Thanks for any advice! Quote Link to comment Share on other sites More sharing options...
wdwerker Posted August 24, 2016 Report Share Posted August 24, 2016 "Gloss dark oak " what kind of finish is that? I would rub down with a gray abrasive pad ( like Scotch Brite) and mineral spirits. Then there would be no need to sand. Quote Link to comment Share on other sites More sharing options...
xxdabroxx Posted August 24, 2016 Report Share Posted August 24, 2016 I get the feeling he is trying to stain the pine legs the color of gloss dark oak, probably one of those minwax all in one stains? Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted August 25, 2016 Report Share Posted August 25, 2016 I would consider a coat of shellac between the previous finish and the paint, just as a precaution. Quote Link to comment Share on other sites More sharing options...
Paddy Posted August 25, 2016 Author Report Share Posted August 25, 2016 Thanks for the reply guys. I'm was thinking of using the gloss paint below: https://www.amazon.co.uk/gp/product/B00NFCYR5Y/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 I think I might just give it a god with the rubbing down and mineral spirit. I'll let you guys know how I get on! might be one of those that I don't know the error of my ways till a year down the road! Again thanks for the reply guys! Quote Link to comment Share on other sites More sharing options...
TerryMcK Posted August 25, 2016 Report Share Posted August 25, 2016 Hi Paddy welcome to the forum. As the guys eluded to coating with shellac first of all will be a good option. In the UK a good premixed shellac is Liberon sanding sealer. One or two coats of this before putting the Ronseal on top would be a good option. You might need more than one coat of Ronseal BTW (read the can). https://www.amazon.co.uk/Liberon-SS250-250ml-Sanding-Sealer/dp/B000TVK42Y/ref=sr_1_1?s=diy&ie=UTF8&qid=1472114794&sr=1-1&keywords=sanding+sealer Quote Link to comment Share on other sites More sharing options...
Paddy Posted August 25, 2016 Author Report Share Posted August 25, 2016 Hi Terry, Thanks for the suggestion I've put some on order now! I was planning on two coats of the Ronseal (want to avoid having to re-finish it in the future!) Regards Quote Link to comment Share on other sites More sharing options...
