Rex Edgar Posted August 25, 2016 Report Share Posted August 25, 2016 What are the guidelines for drill press speeds for larger bits. I'm getting ready to drill some large holes 3 1/4" and 3 1/8" in walnut. Is it like router bits, larger slower, and if so how slow? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 25, 2016 Report Share Posted August 25, 2016 Are you using a hand held drill or drill press? In any case, I go as slow as possible while still cutting wood. I see no reason to rush it. Quote Link to comment Share on other sites More sharing options...
Rex Edgar Posted August 25, 2016 Author Report Share Posted August 25, 2016 I don't weigh enough to chuck a 3"+ bit in a hand held drill. My old bones snap too easily....... Quote Link to comment Share on other sites More sharing options...
Immortan D Posted August 25, 2016 Report Share Posted August 25, 2016 Forstner bits, right? According to my chart, 450 RPM for 3" on hardwoods. Doesn't go beyond 3" BTW. 2 Quote Link to comment Share on other sites More sharing options...
Dave's Not Here Posted August 25, 2016 Report Share Posted August 25, 2016 You might want to print this out for future reference; http://images.meredith.com/wood/images/pdf/speedchart.pdf 2 Quote Link to comment Share on other sites More sharing options...
gee-dub Posted August 26, 2016 Report Share Posted August 26, 2016 On 8/25/2016 at 4:33 PM, Dave's Not Here said: You might want to print this out for future reference; http://images.meredith.com/wood/images/pdf/speedchart.pdf This one is stuck up next to my DP. Provides guidelines if I need them and reminds me that the proper speed for the bit makes a big difference in the quality of the cut. Quote Link to comment Share on other sites More sharing options...
ben_r_ Posted September 14, 2016 Report Share Posted September 14, 2016 This is the one I have laminated and keep in the shop next to the drill press: LINK Quote Link to comment Share on other sites More sharing options...
TerryMcK Posted September 14, 2016 Report Share Posted September 14, 2016 Both those linked charts are good. The advice is the larger the diameter the slower the spindle speed. That way the cutting edge of a bit on the periphery of the tool should always be a similar linear speed. Quote Link to comment Share on other sites More sharing options...
