MisterDrow Posted September 29, 2016 Report Share Posted September 29, 2016 Anyone here ever used the Beadlock system for loose tenons? I am nowhere near being able to afford a Domino and this looked like a pretty viable alternative in the mean time. Certainly not as fast but definitely seems effective. Quote Link to comment Share on other sites More sharing options...
shaneymack Posted September 29, 2016 Report Share Posted September 29, 2016 Do you have a router? You dont need anything fancy, router and edge guide does a great job. Sent from my SM-N910W8 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Eric. Posted September 29, 2016 Popular Post Report Share Posted September 29, 2016 Yeah I'm with Shane...just do traditional M&T until you can buy a Domino. By that time you will have earned it. I think too many new woodworkers try to find ways around fundamental techniques to their own detriment. Learn the basics then figure out how best to cheat. 3 Quote Link to comment Share on other sites More sharing options...
davestanton Posted September 29, 2016 Report Share Posted September 29, 2016 Yes to using beadlock. It is ok and does give you an anti twist dowel using a drill and their jig. I hear most people complain about the cost of the actual beadlock dowels but you can buy a router bit to create the same profile. It is pretty quick and you can also use their mortise chisel guide to create a flat sided hole if you don't want to use the beadlock tenon sticks. 1 Quote Link to comment Share on other sites More sharing options...
gee-dub Posted September 29, 2016 Report Share Posted September 29, 2016 Beadlock joints fail early in the stress tests. Like dowels they have little face grain glue surface. That being said, both are still pretty stout. I use a router for floating tenon joinery and probably do it enough to justify a Domino but, . . . nah. I can still hold a router up . 1 Quote Link to comment Share on other sites More sharing options...
MisterDrow Posted September 29, 2016 Author Report Share Posted September 29, 2016 34 minutes ago, shaneymack said: Do you have a router? You dont need anything fancy, router and edge guide does a great job. Sent from my SM-N910W8 using Tapatalk You know, if I could go back and do it again, I'd have bought a plunge router instead of a fixed-base one... looking to pick one up next month for my birthday. 8 minutes ago, Eric. said: Yeah I'm with Shane...just do traditional M&T until you can buy a Domino. By that time you will have earned it. I think too many new woodworkers try to find ways around fundamental techniques to their own detriment. Learn the basics then figure out how best to cheat. Sent from my SCH-I545 using Tapatalk I'm still going to do traditional M&T... going to be doing it this weekend, actually. Loose tenon joinery still looks really appealing and I was merely curious about the beadlock system. I completely understand the sentiment, though. As a software developer I liken it to those who use WYSIWYG interfaces to build applications (usually mobile) so that they don't have to learn the fundamentals of programming. There's a reason that you should learn and become comfortable with that stuff early on... and then once you are familiar with it, you will often find the non-programming programming methods to be awful. Not a perfect analogy since loose tenons are not generally awful... but I think you see what I mean. 7 minutes ago, davestanton said: Yes to using beadlock. It is ok and does give you an anti twist dowel using a drill and their jig. I hear most people complain about the cost of the actual beadlock dowels but you can buy a router bit to create the same profile. It is pretty quick and you can also use their mortise chisel guide to create a flat sided hole if you don't want to use the beadlock tenon sticks. Very cool. It'll be a while before I get one but I think it could be nice to use once in a while when I don't have time (and the importance isn't as high) for traditional joinery. 5 minutes ago, gee-dub said: Beadlock joints fail early in the stress tests. Like dowels they have little face grain glue surface. That being said, both are still pretty stout. I use a router for floating tenon joinery and probably do it enough to justify a Domino but, . . . nah. I can still hold a router up . That surprises me. Given that the mortise is the same shape as the beadlock tenons I figured the face grain surface contact would still be very high. Quote Link to comment Share on other sites More sharing options...
Popular Post Eric. Posted September 29, 2016 Popular Post Report Share Posted September 29, 2016 You can make a loose tenon with just a router and some scrap. David Marks did it constantly on Woodworks. Just route your mortise, then cut some scrap stock to the exact thickness of the mortise. Use a roundover bit on the tenon stock and it'll fit the mortise like a glove. You can make some grooves on the tenons to eliminate the glue's hydraulic pressure...makes it easier to get them in. 4 Quote Link to comment Share on other sites More sharing options...
mkrusen Posted September 29, 2016 Report Share Posted September 29, 2016 Marc does the above mentioned loose tenon technique in the Krenov cabinet guild build. Its a nice technique and definitely easy to achieve without buying a piece of equipment that you'll end up replacing down the road if you're planning to get a Domino. 1 Quote Link to comment Share on other sites More sharing options...
gee-dub Posted September 29, 2016 Report Share Posted September 29, 2016 1 hour ago, MisterDrow said: That surprises me. Given that the mortise is the same shape as the beadlock tenons I figured the face grain surface contact would still be very high. Don't get me wrong. Beadlock and dowel joints are quite stout. When you start comparing a dowel joint that fails around 750lbs to a beadlock that fails around 830 lbs to a floating tenon that fails around 1400 lbs you have to ask; will I ever put 800 lbs of force on that joint!?! Look how much cope and stick cabinetry is in kitchens all over the country and they fail at around 320 lbs. One that surprised me was that a half-lap was stronger than a bridal joint. I would have thought the captured open tenon would be stronger but, it seems the thicker material of a half lap wins. Festoolians reel seeing dominos holding only a little better than biscuits but, not as good as pocket screws.with glue. Beadlock: Floating tenon: I have also seen tests where epoxy was substituted for PVA glue. The joints where the connection points failed did better but, most joints fail at the surrounding material. The more seamless that connection, the more stress is transferred away from the joint and into the balance of the material. You need to be a subscriber for this link but, there are other tests out there on the internet that are similar. I try not to go too weird-science on this stuff. There are plenty of joints, some stronger or weaker than each other, that are just fine for what we're doing. 1 Quote Link to comment Share on other sites More sharing options...
MisterDrow Posted September 29, 2016 Author Report Share Posted September 29, 2016 9 minutes ago, gee-dub said: Beadlock: Floating tenon: Interesting... I think I thought the beadlock tenons would fit more snugly in the mortise than that.I'll have to experiment with doing them with a router and my own stock... but that doesn't seem like it would be any less work than just doing a standard M&T, either. Maybe I'll hold off for a while... if I need alignment I've always got my biscuit joiner and if I need something fast I can always just use dowels... and then I'll stick to traditional joinery for the rest. Thanks for educating me, gentlemen! Quote Link to comment Share on other sites More sharing options...
Eric. Posted September 30, 2016 Report Share Posted September 30, 2016 To be honest I totally ignore those stress tests. Not only are they scientifically flawed, I simply don't care. Truth is almost any of those joints will be strong enough to withstand normal use, and as long as a piece isn't abused, they should all be sufficient, give or take the piece's function. It boils down to what is the best joint for strength and aesthetics that you can get done quickly and still be proud of. If biscuits are structurally sufficient for a piece and they will never be seen, I'll use them. If the joint is visible and requires additional strength, then it's time to use dovetails. But I'm not gonna get in a twist over a few pounds per inch because some woodworking magazine (which employs exactly zero scientists) says I should. You always know in your gut if the joint you're choosing is appropriate. And like Trip used to say (RIP)..."when there is doubt, there is no doubt." So choose another. 2 Quote Link to comment Share on other sites More sharing options...
gee-dub Posted September 30, 2016 Report Share Posted September 30, 2016 Also interesting that Mathias' end grain to face grain joints tended to fail at the glue line: Where Finewoodworking's end grain to edge grain joints all failed in the wood. Quote Link to comment Share on other sites More sharing options...
Eric. Posted September 30, 2016 Report Share Posted September 30, 2016 That's an apples to oranges comparison, gee-dub. The face grain in MW's test is much stronger than the edge grain in FWW's test. Think about the way wood wants to cleave and the failure in both make sense. 1 Quote Link to comment Share on other sites More sharing options...
MisterDrow Posted September 30, 2016 Author Report Share Posted September 30, 2016 42 minutes ago, gee-dub said: Also interesting that Mathias' end grain to face grain joints tended to fail at the glue line: I'll have to go watch it again but I didn't think he used glue on the pocket hole joints for this test since so many projects online don't. 40 minutes ago, Eric. said: That's an apples to oranges comparison, gee-dub. The face grain in MW's test is much stronger than the edge grain in FWW's test. Think about the way wood wants to cleave and the failure in both make sense. This is absolutely true. FWW's test is at the end of the wood piece whereas MW's is in the middle and on face grain, not edge grain. Quote Link to comment Share on other sites More sharing options...
Immortan D Posted September 30, 2016 Report Share Posted September 30, 2016 Main problem with dowels is that they have the tendency to loosen over time if the joint is under stress. It happens a lot on chairs. Quote Link to comment Share on other sites More sharing options...
gee-dub Posted September 30, 2016 Report Share Posted September 30, 2016 1 hour ago, Eric. said: That's an apples to oranges comparison, gee-dub. The face grain in MW's test is much stronger than the edge grain in FWW's test. Think about the way wood wants to cleave and the failure in both make sense. Agreed. That is the point I was trying to make. I make a lot more joints like FWW does than the way MW does. The test gives us a good "difference" between joints either way but, the joinery method is certainly an influence. I really shouldn't post before the coffee kicks in . 1 Quote Link to comment Share on other sites More sharing options...
MisterDrow Posted October 3, 2016 Author Report Share Posted October 3, 2016 On 9/30/2016 at 7:42 AM, gee-dub said: Agreed. That is the point I was trying to make. I make a lot more joints like FWW does than the way MW does. The test gives us a good "difference" between joints either way but, the joinery method is certainly an influence. I really shouldn't post before the coffee kicks in . Don't feel too bad. I can't person without coffee. 1 Quote Link to comment Share on other sites More sharing options...
galturner Posted October 4, 2016 Report Share Posted October 4, 2016 I think you asked if anyone had experience with this Beadlock, and how did it perform. Well I've used one for 15??yrs. It's the poor women's domino. If you get the large kit, you can make standard M&T with help to keep the sides straight. The jig makes it faster to make a good joint, than by hand. The domino is faster and way more expensive. my 2cents. 2 Quote Link to comment Share on other sites More sharing options...
weithman5 Posted October 5, 2016 Report Share Posted October 5, 2016 On Friday, September 30, 2016 at 7:25 AM, Eric. said: To be honest I totally ignore those stress tests. Not only are they scientifically flawed, I simply don't care. Truth is almost any of those joints will be strong enough to withstand normal use, and as long as a piece isn't abused, they should all be sufficient, give or take the piece's function. It boils down to what is the best joint for strength and aesthetics that you can get done quickly and still be proud of. If biscuits are structurally sufficient for a piece and they will never be seen, I'll use them. If the joint is visible and requires additional strength, then it's time to use dovetails. But I'm not gonna get in a twist over a few pounds per inch because some woodworking magazine (which employs exactly zero scientists) says I should. You always know in your gut if the joint you're choosing is appropriate. And like Trip used to say (RIP)..."when there is doubt, there is no doubt." So choose another. I agree with this. with the exception that I think (I am not 100% sure anymore) that Brian, the editor from woodsmith was a test engineer. (And I am not claiming that it matters.) Quote Link to comment Share on other sites More sharing options...
Popular Post Isaac Posted October 6, 2016 Popular Post Report Share Posted October 6, 2016 On 9/30/2016 at 7:25 AM, Eric. said: To be honest I totally ignore those stress tests. Not only are they scientifically flawed, I simply don't care. Truth is almost any of those joints will be strong enough to withstand normal use, and as long as a piece isn't abused, they should all be sufficient, give or take the piece's function. It boils down to what is the best joint for strength and aesthetics that you can get done quickly and still be proud of. If biscuits are structurally sufficient for a piece and they will never be seen, I'll use them. If the joint is visible and requires additional strength, then it's time to use dovetails. But I'm not gonna get in a twist over a few pounds per inch because some woodworking magazine (which employs exactly zero scientists) says I should. You always know in your gut if the joint you're choosing is appropriate. And like Trip used to say (RIP)..."when there is doubt, there is no doubt." So choose another. I'm with Eric with some caveats. This actually gets into the heart of my actual profession, I'm a structural engineer. It gets pretty technical pretty fast, but the problem with these tests is the shear number of variables at play. Some of the key variables include: Glue strength Wood strength (not only do woods have different strength values, but as we all know, the strength varies depending on direction of loading, and the ratio of these different strengths is not consistent from species to species) Dimensions of the joint - ie. how wide, long, deep is the tenon vs the dowels vs. the bridal etc. Cover - How close is the joint to the end or sides of the side or main member being connected? How will the joint be loaded? Will the loading be repeated, cyclical or one time? Will the loading alternate direction? Will the joint be loaded perpendicular to the main loading direction ever? will these happen concurrently? Will the wood/joint ever be loaded when wet or in a very high humidity situation? There is no way to gleam some universal load value for a given connection. It is a bit like asking how much can you lift? For any normal able bodied person, the answer will depend on what you are lifting, how you are lifting it, etc. for example, typically someone's one handed bicep curl will be a lot less than their bench press, which will be less than what they can leg press or squat. Further, the weight in question is only part of the equation, there is also the basic question of bending. I'm sure everyone remembers playing on a teeter-totter, and how moving the same people (or weight) around can yield different results for who is up and who is down. So two joints might be equally strong for one loading condition and distinctly different for another, or the positions might actually reverse. That doesn't mean all connections are equal or the tests have no value, it just means you really need to scrutinize these things to make sure you are comparing apples to apples and that the test is even valid for the actual stresses the joint is likely to see and back to others point, in general many of these connections, when well made, are very strong and more than adequate for normal loading (ever try to disassemble/smash apart a fully cured joint? they can be quite robust). 3 Quote Link to comment Share on other sites More sharing options...
Isaac Posted October 6, 2016 Report Share Posted October 6, 2016 Just remembered one other I should have included. Joint construction quality (craftsmanship). If you can knock out a super tight beadlock or dowel joint, vs a wiggly mortise and tenon, that will influence the performance significantly as well. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Eric. Posted October 6, 2016 Popular Post Report Share Posted October 6, 2016 3 hours ago, Mike. said: Add to every thing Isaac said, there is a tremendous amount of variability in strength even within species. Or even between two boards, of the same species, from the same log...one will most likely be weaker than the other simply due to its unique grain structure - however little difference there may be, there is a difference. Which cannot be taken into account in any test since every board is unique. 4 Quote Link to comment Share on other sites More sharing options...
gee-dub Posted October 7, 2016 Report Share Posted October 7, 2016 All good points. Fine Woodworking made 5 of each joint, tested and averaged the result. This levels the playing field somewhat but, the variety in characteristics is pretty plentiful. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted October 7, 2016 Report Share Posted October 7, 2016 Nevertheless, Mattias garnered a good number of views for that video, and others like it. Quote Link to comment Share on other sites More sharing options...
Popular Post CharleyL Posted October 22, 2016 Popular Post Report Share Posted October 22, 2016 I own a Beadlock jig, but also own a Leigh FMT Pro. I now do all of my M&T joints on the FMT, but I got started many years ago with a standard 3/8" Beadlock. It's a great, easy to learn, low budget jig that will produce great results and the only power tool that you need to use with it is a hand drill. Of course, a power saw might be great for cutting the tenon stock to length, but a hand saw is almost just as easy. I made one modification to my Beadlock jig. The gold plating on the jig's alignment line gave me trouble because it was difficult for me to see the edge of it. I filed this gold plating off of the surface (the flat surface facing you - do not file the side of the hole) around this alignment marker, and then colored the exposed metal with a black marking pen. After doing this it was very easy for me to see and align this edge to the position mark on my board. Learning to insert spacers between the drill guide block and the jig allows you to offset the joint to make table legs join proud (stick out) from the table rails, etc. so the two surfaces don't always have to be the same. I have loaned out my Beadlock several times to newer, less experienced, woodworkers and all have achieved good results with it. It's a good and relatively cheap way to get started doing M&T joints. Charley 3 Quote Link to comment Share on other sites More sharing options...
