need help with miters.
Riley
Hi all,
sorry if this is the wrong forum but i need some help with miters. I am making a table using walnut backed plywood as the top and I am trying to frame the top with some cherry strips to hide the edge of the plywood. I am trying to use 90deg miters for the cherry frame. these miters are killing me! I can not get them square or to match up and i also can't keep the length right. I am using a  compound miter saw to cut the 45deg on each end of my frame pieces. I am using a speed square and a starrett square to set the vertical angle and miter angle. After chopping them i then use a shooting board to touch up the cuts.
So far i have made 3 full sets and none of them come out anywhere near good. Sometimes i get 3 good corners but the 4th one is bad and the more i try to adjust it the worse it gets then i end up with the board getting too short.
I dont have many tools right now. I have the compound miter saw, a track saw, a low angle jack plane, hand plane, some chisels and a couple Japanese hand saws.
Any advice? Im not looking for perfection but i right now i can put a quarter into my gaps.
Thanks all.
-Riley
Obviously, something is off.  In your case, I would suspect that you have a few small errors that add up to kicking you in the back side.
1.  Square ply - I get what you're doing and understand.  Check the corners of the actual piece with your starrett square to make sure they're square.  I usually trust their squares but, be sure this square is actually square.
2.  What miter saw do you have and do you trust the 45 stop?  Someone above mentioned a sled for a table saw but, you didn't list that as one of your tools.  You need a way to truly verify 45 on your miter saw each time. A small error compounded 4 times makes a huge difference.
3.  You mentioned that you had a shooting board but, did'nt give much info about it.  Did you make it yourself? Is it dead on 45? what plane are you using to shoot it?
Some pictures of what you're doing might help.
Welcome to the forums.
another problem i have is that I have to use S4S lumber from the box store because I dont have the ability to mill it myself. after looking at my stock is apparent that the strips of cherry are not perfectly flat and straight either. I  may be trying to use a very exact technique with sup optimal lumber.
any other ideas on how to hide the edge of the plywood?
-Riley
-Riley
Yep, that'll kick you in the back side too..  You could edge band it or, you could use solid lumber instead of the ply.
Use your plane to square up your frame pieces as best you can. Once you get the front side of the piece flat, the shooting board should help squaring up the 2 narrow sides and back side.  Then it is matter of starting at one corner and working you way around and fitting each miter as you go.  Of course the last piece is the trickiest. As you cut each piece to length, start long and then sneak up on you exact length.  Good luck.
Your big box store has cherry?  Impressive.  No doubt very expensive, but impressive they have it.
I have come to the realization that true perfect miters, even though it seems like it is easy, is a very advanced technique.  It takes trial and error, practice and patience to figure what works for you.  I'm not there yet.
Box store near me has s4s mahogany.
I'm supper appritiative of all the help and advice. I think that out of my frustration im going to switch to a different joint. Im going to practice some half laps, box joint, and maybe a large single dove tail and see if that works better.
oh and ill post some pictures along the way.
thanks all,
-Riley
thanks all,
-Riley
I think that's a good call. What you were trying to do originally looks simple, but can be fiendishly difficult to execute, especially if you don't have a lot of experience. Looking forward to seeing your project.
  • Who's Online   2 Members, 0 Anonymous, 53 Guests (See full list)
    31.2k
    422k
    23,769
    TJJirak
    TJJirak
