treesner Posted October 17, 2016 Report Share Posted October 17, 2016 Do you guys have a good technique for drilling tall pieces on the drill press? I tried clamping to my table but it was hard to keep it vertical and then center it and then clamp it down. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted October 17, 2016 Report Share Posted October 17, 2016 You could make a vertical clamping block that attaches around the post. Depends on the shape of the object to be drilled, I guess. Can't see your photos at the moment, for some reason. Quote Link to comment Share on other sites More sharing options...
Coop Posted October 18, 2016 Report Share Posted October 18, 2016 I made an L shaped brace from 2x's and clamped in similiar fashion as you've done, to the drill press. Then clamped my piece to the inside of the brace, taking care to plumb it to your drill bit, and it gave it more substance to clamp to. Quote Link to comment Share on other sites More sharing options...
AJ_Engineer Posted October 18, 2016 Report Share Posted October 18, 2016 Does your table rotate 90 degrees? It looks like yours does (round barrel and angle gauge). Clamp the piece flat on the table and rotate the table. 2 Quote Link to comment Share on other sites More sharing options...
Ronn W Posted October 18, 2016 Report Share Posted October 18, 2016 I agree with AJ. Rotate the table. You can still let your work piece bear on the table. You can even draw a line on the rotated table or clamp a guide to the rotated table to help you align the piece vertically. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted October 18, 2016 Report Share Posted October 18, 2016 That drill press looks familiar. There may be a pin that keeps the table flat even when the locking nut is loosened. Use a drift punch to tap the pin out and the table should rotate freely. Quote Link to comment Share on other sites More sharing options...
