DennisR Posted December 19, 2016 Report Share Posted December 19, 2016 I glued purple heart with maple and when sanding the maple was being darkened by the purple heart or something. I was not as white when I started. how do I prevent this when gluing dark and light wood together and sanding? Quote Link to comment Share on other sites More sharing options...
Tpt life Posted December 19, 2016 Report Share Posted December 19, 2016 Try a card scraper from light to dark. Quote Link to comment Share on other sites More sharing options...
Coop Posted December 19, 2016 Report Share Posted December 19, 2016 I agree. You're sanding the Purple Heart dust into the maple. Like washing colored clothes with your whites. 2 Quote Link to comment Share on other sites More sharing options...
DennisR Posted December 19, 2016 Author Report Share Posted December 19, 2016 thanks for quick reply I tried sanding but will try scraper. is there a way to prevent this other than sanding before gluing and don't sand after glued together? Quote Link to comment Share on other sites More sharing options...
JosephThomas Posted December 19, 2016 Report Share Posted December 19, 2016 1 hour ago, DennisR said: thanks for quick reply I tried sanding but will try scraper. is there a way to prevent this other than sanding before gluing and don't sand after glued together? You could try doing a seal coat before sanding to fill the grain and pores a little. You'd have to test this out on some scraps to figure out the right amount of sealing to do. 1 Quote Link to comment Share on other sites More sharing options...
phinds Posted December 19, 2016 Report Share Posted December 19, 2016 9 hours ago, DennisR said: I glued purple heart with maple and when sanding the maple was being darkened by the purple heart or something. I was not as white when I started. how do I prevent this when gluing dark and light wood together and sanding? You think that's bad, try it some time with padauk. Joseph has the right idea ... use a pore filler before sanding. Also, if try doing all but the last grit or two with a belt sander with the belt moving light to dark and then finish with a high grit on a ROS. 1 Quote Link to comment Share on other sites More sharing options...
