Audiokat Posted January 3, 2017 Report Share Posted January 3, 2017 Could I put a few coats of salad bowl finish on after using mineral oil? I've used SBF a few times and loved the result and longevity. I recently did a set of boards with just mineral oil. After four coats and some cure time my wife washed a board after using the grain rose substantially. Im sure I could sand all the way down and start over but it would be nice to just add a few coats of bet salad bowl finish. Quote Link to comment Share on other sites More sharing options...
Brendon_t Posted January 3, 2017 Report Share Posted January 3, 2017 I have tried it and the results were garbage. The sbf was still gummy after a week or so. I assume because mineral oil never actually does out. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted January 3, 2017 Report Share Posted January 3, 2017 Nothing's going to dry well on top of mineral oil. Maybe wiping several times with laquer thinner might work to remove the oil ? Try a small patch and if the Salad bowl finish dries you could do the rest of the board. Quote Link to comment Share on other sites More sharing options...
Audiokat Posted January 3, 2017 Author Report Share Posted January 3, 2017 Sorta what I figured. Maybe I'll just let the wife use it for a few months. It will dry out and a lot of the oil will get washed out. Then I guess I will just sand and do it over. Live and learn. Quote Link to comment Share on other sites More sharing options...
Popular Post wtnhighlander Posted January 3, 2017 Popular Post Report Share Posted January 3, 2017 Beeswax is excellent with mineral oil. Yes, it still requires periodic maintenance, but nowhere near as much as you think. 3 Quote Link to comment Share on other sites More sharing options...
Marmotjr Posted January 3, 2017 Report Share Posted January 3, 2017 1 hour ago, wtnhighlander said: Beeswax is excellent with mineral oil. Yes, it still requires periodic maintenance, but nowhere near as much as you think. This is what I use. I use roughly a 2:1 mineral oil to beeswax mix, but it's difficult to measure out cold, as the wax is solid. I put it on a hot plate to melt and mix everything, then apply it with a rag. 2 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted January 3, 2017 Report Share Posted January 3, 2017 This is what I use. I use roughly a 2:1 mineral oil to beeswax mix, but it's difficult to measure out cold, as the wax is solid. I put it on a hot plate to melt and mix everything, then apply it with a rag. Same here. Initially, I use a mix that is mostly oil, but after a couple of coats soak in, I switch to more wax. The "maintenance" formula is about the consistency of wax shoe polish. 1 Quote Link to comment Share on other sites More sharing options...
