pideja Posted January 10, 2017 Report Share Posted January 10, 2017 I mistakenly purchased Minwax Super Fast-Drying Polyurethane for Floors in the satin finish rather than the semi-gloss for my hardwood floors. I also purchased some gloss finish Minwax Super Fast-Drying Polyurethane. Is it possible to somehow combine the two products in order to get a less "flat" finish than is possible with the satin alone. Of course, I would have to figure out the correct proportions in order to match the existing finish of my floors. You see, I am attempting to "renew" parts of the floors that are worn by use and not the whole floor. I realize their is also the question of applying the new polyurethane so that the outer edges are on a gradient in order to blend with the existing floor finish.Can this be done? Quote Link to comment Share on other sites More sharing options...
wdwerker Posted January 10, 2017 Report Share Posted January 10, 2017 The satin has a flattening agent in it. It must be stirred up quite well before using or mixing. As to matching the existing floor sheen that's going to take a good bit of testing and careful application. Practice on the least visible spots. If you wait a week or more you might be able to use an grey or white abrasive pad to reduce the sheen on a too glossy spot. Or you could buff the entire floor . Quote Link to comment Share on other sites More sharing options...
