freedhardwoods Posted January 15, 2017 Report Share Posted January 15, 2017 I spotted this on Craigslist. 2hp, 220volt. They say it runs good. what would it be worth? Quote Link to comment Share on other sites More sharing options...
RichardA Posted January 15, 2017 Report Share Posted January 15, 2017 It looks like it needs a bunch of work, that fence is kinda weird looking. And I'd bet it needs bearings. It runs, all that means is the switch works. It looks like the table top is going in many directions, but that could just be the pic or camera angle. Price wise, considering the work, I'd offer $400 and see what they say...But you won't really know much til you get up close and personal, with a straight edge and some wood. Quote Link to comment Share on other sites More sharing options...
treeslayer Posted January 15, 2017 Report Share Posted January 15, 2017 i'm with @RichardA, 400 would be my top dollar, it looks well used and i think its an older model, i think you will end up throwing money at it but at 400 you do have some room for whatever issues it has. also, 2hp sounds light for that saw especially a 220v one, i think those were 3hp at a minimum. i would have to hear it run, check bearings ect. and go from there. Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted January 15, 2017 Report Share Posted January 15, 2017 I would agree that saw probably needs some work, it also looks like the table is on backwards. I would prefer a cast wing and the fence looks beefy and should work, but I would probably swap with a piece of extruded aluminum. I wouldn't go more than $425 for the saw. I thought the 220 versions had at least 3 hp motors, I could be wrong though. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted January 15, 2017 Report Share Posted January 15, 2017 $400 sounds like a reasonable top offer. The extension wing is stamped steel, and looks mis-aligned. The fence is original, I believe. Looks just like the one on Norm Abram's saw. Quote Link to comment Share on other sites More sharing options...
RichardA Posted January 15, 2017 Report Share Posted January 15, 2017 6 minutes ago, Woodenskye said: I would agree that saw probably needs some work, it also looks like the table is on backwards. I would prefer a cast wing and the fence looks beefy and should work, but I would probably swap with a piece of extruded aluminum. I wouldn't go more than $425 for the saw. I thought the 220 versions had at least 3 hp motors, I could be wrong though. You got it right, I didn't catch that, the table does look backwards. There's no blade showing, and that makes me wonder! Quote Link to comment Share on other sites More sharing options...
knotscott Posted January 15, 2017 Report Share Posted January 15, 2017 I don't think that's a Unisaw. It would say "Unisaw" on the front if it really was. More likely a 36-755 hybrid with table mounted trunnions like a contractor saw. The Unifence is a good fence, but its right tilt, pre-riving knife, has a steel wing, and no warranty. If it's in good working order $400ish seems about right. 1 Quote Link to comment Share on other sites More sharing options...
Tpt life Posted January 15, 2017 Report Share Posted January 15, 2017 They go in the 300-350 range all the time about three hours north of you. Quote Link to comment Share on other sites More sharing options...
Chet Posted January 15, 2017 Report Share Posted January 15, 2017 Yea thats a Unifence, I had one on my Delta Contractor saw. Its one of the nicest fences I ever used. Great fence if it is good shape of course the rest of the saw has to work too. Quote Link to comment Share on other sites More sharing options...
freedhardwoods Posted January 15, 2017 Author Report Share Posted January 15, 2017 I threw that post up real quick before I left for church. It has a blade in this pic. They're asking $350. I found other ads asking $600 - $1400 for better looking units. The backwards table makes me think he found it in pieces and put it together. Thanks for the comments. I know nothing about Unisaws. Any more info I should know? Quote Link to comment Share on other sites More sharing options...
Chet Posted January 15, 2017 Report Share Posted January 15, 2017 I do know that the clear plastic cursor for the fence is no longer made. I had to replace mine about 6 years ago and the one I found online was a mirror image of mine, th mounting holes were on the other side. Apparently they changed them recently. So if this one is damaged you will need to make your replacement. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted January 15, 2017 Report Share Posted January 15, 2017 600 reflects the cost of a 3-5 HP unit up here. 350 is fair for the 1.75 you get out of an old 2HP saw. Production shops will sell when overhauls are expected. Prepare to replace all bearings in the near future. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted January 15, 2017 Report Share Posted January 15, 2017 Unisaw or hybrid, that's not a bad deal for $350. Point out the wonky table, maybe get them to knock off another $25 or so. 1 Quote Link to comment Share on other sites More sharing options...
freedhardwoods Posted January 15, 2017 Author Report Share Posted January 15, 2017 I think I'm going to pass on it. I have enough to do already without overhauling machinery right now. This is the ad if anyone else is interested. https://indianapolis.craigslist.org/tls/5956738804.html Quote Link to comment Share on other sites More sharing options...
mat60 Posted January 15, 2017 Report Share Posted January 15, 2017 I have that sliding table and love it. Quote Link to comment Share on other sites More sharing options...
Seth Clayton Posted January 15, 2017 Report Share Posted January 15, 2017 17 minutes ago, freedhardwoods said: I think I'm going to pass on it. I have enough to do already without overhauling machinery right now. This is the ad if anyone else is interested. https://indianapolis.craigslist.org/tls/5956738804.html Looks like that's a different saw. $2500 for that one and it's in great shape! I'm in Indianapolis as well. I'll look at any of your sloppy seconds! LOL Quote Link to comment Share on other sites More sharing options...
freedhardwoods Posted January 15, 2017 Author Report Share Posted January 15, 2017 30 minutes ago, Seth Clayton said: Looks like that's a different saw. $2500 for that one and it's in great shape! I'm in Indianapolis as well. I'll look at any of your sloppy seconds! LOL Whoops! He must have sold it already. He deleted the ad. He just put it in last night. Quote Link to comment Share on other sites More sharing options...
Andy Wright Posted January 16, 2017 Report Share Posted January 16, 2017 Couple of notes: 1) the table isnt backwards - those saws came with a "left tilt" or "right tilt" option on the blade. This model is "right tilt" which means that the blade tilts towards the fence (opposite of most saws) 2) the fence is a Delta Unifence which was a more expensive option than the Biesemeyer. I had a Unifence for several years and it is a nice fence 3) this is a "Tilting Arbor" which was a less expensive cousin to the unisaw. That is the reason why it is only 2HP. It has lighter trunnions than a Unisaw and that is also why it has a stamped steel wing. This was one of the first "hybrid saws" that fits between a true cabinet saw and a contractor saw If it was a Unisaw, $350 would be a steal. I have a Unisaw that I bought used 12 years ago and it still runs great 1 Quote Link to comment Share on other sites More sharing options...
