HShah Posted January 18, 2017 Report Share Posted January 18, 2017 We have a problem in MDF panel natural wood veneering. We intend to natural wood veneering cabinet and CNC machined 3d panel (with MDF core). We tested it with 0.3mm back fleeced wood veneer and the following glue:http://www.glue4u.com/index.php/data-sheets/tds-a-msds/jowat/436-150-90-tds We also use membrane hot press machine without vacuum capability. Unfortunately it didn’t work correctly. The wood veneer didn’t form well, especially in the concave area. You can see the final result of our failed test in the following link: http://postimg.org/image/cpt2ifz19http://postimg.org/image/urc7g8t25 Can someone help me? Should I change the type of veneer or glue? Do you have any idea? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted January 18, 2017 Report Share Posted January 18, 2017 I suspect that the veneer is simply not flexible enough to form around the tight corners of the recess without splitting. You might try steaming or boiling the veneer to soften it. This would probably require a glue that cures in the presence of moisture, similar to the 'Gorrilla Glue' original. Veneering is not my thing, maybe a better answer will appear shortly. 1 Quote Link to comment Share on other sites More sharing options...
HShah Posted February 4, 2017 Author Report Share Posted February 4, 2017 On 1/18/2017 at 3:20 PM, wtnhighlander said: I suspect that the veneer is simply not flexible enough to form around the tight corners of the recess without splitting. You might try steaming or boiling the veneer to soften it. This would probably require a glue that cures in the presence of moisture, similar to the 'Gorrilla Glue' original. Veneering is not my thing, maybe a better answer will appear shortly. Thank you for your suggestion. Has anyone ever had any success with any type of veneer softener? Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 4, 2017 Report Share Posted February 4, 2017 That process doesn't work with natural wood veneer. They use a pvc film. And they use heat + vacuum . 1 Quote Link to comment Share on other sites More sharing options...
