mandarb777 Posted February 18, 2017 Report Share Posted February 18, 2017 Hi everybody, This is my first post and I have a question about using a step down/step up transformer with power tools. I'm currently renting and the landlord let's me use the basement for my shop. But I need more power, specifically for my table saw (craftsman contractor 1ish HP) and dust collector both of which are 110. There is an unused 220 volt 30 amp receptacle (for a dryer). Can I use that with the mentioned transformer? I want to be safe and not waste money. Thanks so much! Dave PS. Hope this is in the right place. Quote Link to comment Share on other sites More sharing options...
Coop Posted February 19, 2017 Report Share Posted February 19, 2017 I can't help you on the transformer but I would change the 220 to 120 if you have access to the breaker panel and are knowledgeable in doing so. Quote Link to comment Share on other sites More sharing options...
mandarb777 Posted February 19, 2017 Author Report Share Posted February 19, 2017 Thanks K Cooper, I don't know how to do that. But I also don't want to drop too much money into a place that I'm renting. Part of the appeal of the transformer is that I can take it with me. Is it hard or expensive to do that? Thanks again, Dave Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted February 19, 2017 Report Share Posted February 19, 2017 You can certainly use such a transformer, but if you don't know how to rewire a circuit from 220 to 110, you really need professional help with the transformer. Since you need help anyway, less coat will be involved to hire an electrician to rewire the circuit for you. Transformers aren't cheap. Quote Link to comment Share on other sites More sharing options...
Popular Post drzaius Posted February 19, 2017 Popular Post Report Share Posted February 19, 2017 The dryer outlet is 120/240V, 30A so there's lots of power there, plenty for your shop. But you can't just connect 15A receptacles to it. What you could do (or rather, have an electrician do it) is make up a portable panel. It will take a small 8 circuit panel, some breakers, a few boxes & receptacles & a dryer cord to plug it in. Assemble the whole thing on a piece of plywood that you can hang on the wall. It's possible to have a mix of 15A, 20A, 120V & 240V receptacles. Total cost for parts would probably be less than $150. No need at all for a transformer. Please don't try to do this yourself unless you have an electrician buddy that can assist. Don't rely on advice from home center staff because they generally know far less than they think. Good luck and welcome to the forum. 3 Quote Link to comment Share on other sites More sharing options...
ottacat Posted February 19, 2017 Report Share Posted February 19, 2017 A dryer receptacle is a 4-wire receptacle - 2 hot, 1 neutral and 1 ground. Wiring the 2 hot produce a 240V circuit and wiring 1 hot and the neutral produces a 120V circuit. You can wire a subpanel as drazius has suggested and from there install a range of 120V and 240V circuits although of course your total draw can't exceed 30 amps. Get a knowledgeable friend to give you a hand. Quote Link to comment Share on other sites More sharing options...
Tom King Posted February 19, 2017 Report Share Posted February 19, 2017 The dryer wire might not be a 4 conductor, unless it's a newer one. 1 Quote Link to comment Share on other sites More sharing options...
Andy Wright Posted February 20, 2017 Report Share Posted February 20, 2017 As others have said, the best way to do it is to build a box that converts the 220V down to a pair of 110V outlets. If you have a four prong outlet you can use one of these off the shelf adapters https://www.walmart.com/ip/Conntek-Y1450520S-NEMA-14-50-50-Amp-125-250-volt-RV-Generator-Y-Adapter-Plug-to-U-S-15-20-Amp-Female-Connectors/105629913?wmlspartner=wlpa&selectedSellerId=4133&adid=22222222228053036306&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=m&wl3=152959749748&wl4=pla-264053663920&wl5=9026870&wl6=&wl7=&wl8=&wl9=pla&wl10=113500221&wl11=online&wl12=105629913 1 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 20, 2017 Report Share Posted February 20, 2017 23 minutes ago, Andy Wright said: As others have said, the best way to do it is to build a box that converts the 220V down to a pair of 110V outlets. If you have a four prong outlet you can use one of these off the shelf adapters https://www.walmart.com/ip/Conntek-Y1450520S-NEMA-14-50-50-Amp-125-250-volt-RV-Generator-Y-Adapter-Plug-to-U-S-15-20-Amp-Female-Connectors/105629913?wmlspartner=wlpa&selectedSellerId=4133&adid=22222222228053036306&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=m&wl3=152959749748&wl4=pla-264053663920&wl5=9026870&wl6=&wl7=&wl8=&wl9=pla&wl10=113500221&wl11=online&wl12=105629913 Only if you can find a plug like that for a 30 amp outlet. Different amp ratings of 240 outlets have different blade shapes and positions. I belive there are more than one plug shape for 30 amp dryers, age and code requirements can vary. Quote Link to comment Share on other sites More sharing options...
