Wood curling when cut
Timboslice
Check the moisture content. If you don't have a moisture meter weigh one of the curled strips on an accurate digital scale, record it and weigh every few days. If the weight keeps lessening wait until the weigh stabilizes for a few weeks. If the weight is stable then the wood either grew with tension in it or was poorly dried.
Sometimes there is just a lot of natural stress in some boards and they will curl and maybe try to bind up your saw blade.  I don't have a could solution other than to try a different board.
I would keep a couple of wedges or a flat screwdriver handy to jamb into the the saw kerf behind the blade to keep the kerf from closing up while you complete the cut.  Be careful reaching across the blade.
