Cutting Concrete Floor for In-Floor Dust Collection-- Nuts?
#1
Posted 15 February 2012 - 10:26 AM
But before doing so, I had a brainstorm. Or maybe it's a nightmare.
I would love to run a 6" dust collection pipe UNDER THE FLOOR to my tablesaw which will sit in the very middle of the shop. I hate hanging ducts and my thought is that the tablesaw is the one tool that I think will always remain stationary so I can very precisely locate the in-floor duct location.
To do this would require cutting the perfectly good concrete floor with a masonry saw and then excavating a channel approx 10" wide (if I am running under the floor, I thought I would also install electric and air lines while I am at it).
Is this nuts or a good idea?
Will I be risking making the concrete slab unstable or inviting moisture problems? My thought was excavate the trench, put a layer of landscape fabric, then sand, then the piping , then more sand, then a vapor barrier, then the board insulation, then the plywood flooring. I would screw the plywood over the trench so the piping was accessible.
So, what do you think?
Thanks, Jim
Upstate NY-- the beautiful Finger Lakes....
#2
Posted 15 February 2012 - 10:43 AM
This is not my area of expertise at all, but I'd consider excavating the trench and then starting with concrete on the bottom. That way you have a continuous concrete slab floor, just shaped funny. Remember to check for electrical, gas, etc before excavating.
If you find a post useful and well written,
please support the WoodTalkOnline site.
#3
Posted 15 February 2012 - 10:51 AM
If it's high enough, I might install a raised floor.
#4
Posted 15 February 2012 - 12:21 PM
The thought though of concealing the piping is not bad though...Is your shop wood frame construction with drywall? Open studs?
you might consider running your piping through your attic space instead...its is a lot easier to repair gyp board if you need to relocate a piece of equipment. If you dig a trench to your saw, Murphy's law will almost certainly kick in and force you to move something, then you are REALLY in a tight spot. and what happens if you want to add more tools to the collection line?
If you really want to hide it, you could even run the piping in the walls themselves, up into the attic, and over the ceiling to your collector. If all of your shop walls are exterior, and you don't want to lose insulation, maybe you could even build a false wall (chase wall) for your air lines and collection piping to live in. This way, if your shop really is large, you might only lose 6" of wall depth where the case is...and add more opportunities for recessed storage, and the like.
Maybe you can post some pictures and a sketch of your space with dimensions and I could help with options...
@dozersworkshop
#5
Posted 15 February 2012 - 12:48 PM
If you can avoid cutting the concrete that is the way I would go. If you like swinging a sledge hammer for hours on end then cut away.
#6
Posted 15 February 2012 - 01:00 PM
The ceiling is 12' high so the suggestion to raise the floor is an interesting idea that hadn't occurred to me. Duh! That would provide more room for insulation, wiring throughout the shop, flexibility with running other DC ducting, etc. Would I have to worry about the floor being bouncy with just 3/4" T&G plywood on 16" centers?
The only downside to that approach that occurs to me is that there is a side door and a garage door to the garage so I would have to come up with some method to deal with the raised floor at those two entrances. Hmmm, food for thought!
Keep the ideas coming guys!
#7
Posted 15 February 2012 - 01:09 PM
I like Barry's idea for a raised floor. You would have to plan the joists' locations to allow running of DC pipe, but the big benefit here would be that you could run multiple DC pipes, to include not just your TS but also jointer, planer, assembly/sanding table, CMS, etc etc. Running power lines would also be a huge benefit. This would be more easily reconfigured than concrete cutting, if it ever comes to the point that you want to move stuff around. I would think that such a floor would be fairly stable, since it could be almost continuously supported on the existing concrete (with shims/spacers/etc where needed). You could always double up on the flooring if needed.
If you end up still considering cutting into the floor, you should investigate doing more than just the one run. As long as you're cutting it up, go all out. Maybe price out for a concrete cutting company to do it (at least just the cutting), and also maybe get a 'ballpark' estimate on what it would take to either patch the trenches, or just cut up and replace the entire floor. Just for future reference.
#8
Posted 15 February 2012 - 01:15 PM
#9
Posted 15 February 2012 - 01:42 PM
Don
#10
Posted 15 February 2012 - 06:21 PM
Everything can be hidden, you can make changes of needed, the insulation is a bonus, and it's comfortable.
My previous life was in warehousing. We had a raised mezzanine with a wooden floor and the employees loved it. It was an MDF material with a fancy coating, the stuff would survive a bomb. The little, tiny bit of bounce is nice on the feet. It deadens sound too.
#11
Posted 15 February 2012 - 06:48 PM
It would be easy enough to fill in and pour concrete back if, at some point down the line you decide you want a solid floor back.
#12
Posted 16 February 2012 - 05:18 AM
If you shop carefully, you might be able to get a load of the lowest grade oak flooring at a reasonable price. No need to get all crazy finishing it, a basic sanding and a single coat of varniish is fine for a shop floor.
Too bad it's so hard to find removed computer room floors. They were strong, as mainframe and mini-computer stuff was very heavy, and it's so easy to work underneath.
#13
Posted 16 February 2012 - 06:55 AM
I would talk to someone with very specific knowledge before settling on the plan.
16" centers does not sound appropriate for a shop floor with some heavy equipment.
This is where paying for some expertise can be good investment. They could also help steer you to good choice of flooring and if you'd be best served by a sandwich of materials rather than just 3/4 T&G ply. Keep an open mind on materials.
Have fun with your project.
#14
Posted 16 February 2012 - 08:08 AM
Access flooring is also great for forcing air through your shop...a few of the modular panels fitted with air vents at strategic locations can be great for creating a shop HVAC system. You just have to have a heater or A/C to blow into the underfloor area, then with vents in the floor wherever you need them, you can really pinpoint the areas of the shop to control the climate in, changing locations at will...and no ducting needed since the whole under floor area is the duct.
Doors at slab level are not generally an issue, they just usually leave out an area in front of the door, with steps or a ramp as needed up to the raised floor level.
@dozersworkshop
#15
Posted 16 February 2012 - 09:22 AM
We have a system like this at work, in our computer room. The problem is, we run a lot of other stuff besides HVAC under the floor, so the HVAC ended up getting trapped in one small section of the room. If you're going to run, say, 6" DC duct under the floor, then you'll want the floor about 10" high so the HVAC can get past the duct. For a small garage, I wouldn't use under-floor HVAC.Access flooring is also great for forcing air through your shop...a few of the modular panels fitted with air vents at strategic locations can be great for creating a shop HVAC system. You just have to have a heater or A/C to blow into the underfloor area, then with vents in the floor wherever you need them, you can really pinpoint the areas of the shop to control the climate in, changing locations at will...and no ducting needed since the whole under floor area is the duct.
At work we have 2' square panels sitting on a metal framework. We have a few suction cup "floor suckers" that we use to lift the panels. I might consider wooden skins on both sides of rigid insulation, glued into a sandwich. It would be strong, pretty light, and would add insulation.
I'd also consider a small hatch in the middle of the floor, hooked into the DC, so you can just sweep everything into it.
I wish I could put in a raised floor, but the ceiling is too low in my basement shop as it is.
#16
Posted 16 February 2012 - 09:45 AM
#17
Posted 21 February 2012 - 02:32 PM
#18
Posted 22 February 2012 - 07:18 AM
+1
Cutting into a slab is not a great idea. Know someone who investigated this and it was cheaper to demo the entire slab to the perimeter footing, lay the DC pipe, conduit for electric, water for slop sink and waste line for a shop toilet and pore a new slab. He went for the new floor and loves it, the shop looks unbelievable, but the $$$s were impressive.
#19
Posted 22 February 2012 - 10:32 AM
I'm not right...but I'm happy
#20
Posted 22 February 2012 - 10:37 AM
