Metal work help
#1
Posted 20 February 2012 - 09:17 AM
Thanks in advance!
#2
Posted 20 February 2012 - 09:59 AM
If you find a post useful and well written,
please support the WoodTalkOnline site.
#3
Posted 20 February 2012 - 01:33 PM
#4
Posted 21 February 2012 - 08:38 AM
Lowes or HD carries some smaller sizes of steel and alum, but it is expensive. If you want to try and find it cheaper (or free) stop in a fabrication shop that makes stairs and rails. They have a better chance of having aluminum than a structural shop. Some people will let you root thru the scap bin for what you need. There are also steel warehouses that sell mainly to fabricators but will sell to individuals at a higher price. Most deal only in stock lengths, some will cut for you but don't expect them to cut acurately.
#5
Posted 22 February 2012 - 04:34 PM
I have heard that people have cut aluminum on a table saw by turning the blade around and running it backwards with good luck but, I've never tried that.
If you just need a notch and not cut completely through, I would go to the "old tried and true, hand powered, HACK SAW!
Rog
#6
Posted 22 February 2012 - 05:25 PM
#7
Posted 22 February 2012 - 08:37 PM
#8
Posted 23 February 2012 - 05:00 AM
#9
Posted 23 February 2012 - 07:28 AM
Don
#10
Posted 23 February 2012 - 03:15 PM
rmac, on 22 February 2012 - 08:37 PM, said:
Still evaluating my options at the moment so I don't even have the supplies.
Dave B, on 23 February 2012 - 05:00 AM, said:
Forgive my ignorance, what is an ROS? Also, I'm not certain I will be going with aluminum for this, it's an option that I'm weighing (also considering cold rolled steel). I don't know much about metal, it's strengths/weaknesses across all the options.
Why type of saw blade are you using on your TS for this? Anything special I need to get for router work or do standard router bits (carbide?) work?
#11
Posted 24 February 2012 - 05:51 AM
ROS = I use an old Ridgid random orbital sander, 220 grt
Use standard carbide TS blade and router bits just like you do with wood. If you use a jig saw, spray some WD-40 on the blade otherwise the blade will get hot and fill in with aluminum.
#12
Posted 27 February 2012 - 08:51 AM
I'm not going to be nosey and ask how much strength you need. But, if you are not even sure what material you are going to use.....,
I will recommend that you explain your needs to a machine shop person in person so you can answer a few questions from him. Yes, it will cost some money but, you will probably get what you need without destroying any wood working tools.
I worked in a sheet metal/machine shop for 15 years in a previous life.
Rog
