Byrdie Posted May 22, 2013 Report Share Posted May 22, 2013 I prefer the router table for making stopped dados and rabbets. Other wise it's only used for decorative trim, round over and the like. Through dados and rabbets get done with the dado stack at the table saw. Just my preference. Quote Link to comment Share on other sites More sharing options...
sawdustandwoodchips Posted August 25, 2014 Report Share Posted August 25, 2014 In Sawstops FAQs it states Do not use dado sets with solid-plate interior chippers" what are these? I have a CMT set - that I like a lot - but do they have solid-plate chippers - they are very solid :-) in a fine woodworking article - http://www.finewoodworking.com/how-to/article/how-to-cut-tenons-on-the-tablesaw-with-a-dado-set.aspx in 2009 Michael pekovich is using a similar dado stack. Just looking for clarification. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
sawdustandwoodchips Posted August 25, 2014 Report Share Posted August 25, 2014 I just got a reply from Sawstop Yes that blade is just fine. The FAQs is referring to ones where the chippers are not "wings" but instead full plates like the two outside blades of your stack. Quote Link to comment Share on other sites More sharing options...
ChetlovesMer Posted August 25, 2014 Report Share Posted August 25, 2014 I've had the SawStop ICS for almost 10 years. I've run several different dado heads. Delta, Freud, Dado King, a cheap crappy one from Menards (... don't ask.) Anyhow, I've never had an issue. I've also never adjusted the depth of the break for a dado head. Never tried the Dadonator, however. Quote Link to comment Share on other sites More sharing options...
sawdustandwoodchips Posted August 26, 2014 Report Share Posted August 26, 2014 the issue is not whether it will run - it's whether the brake will stop the stack. surely if you are using 8" dado sets then the standard brake is never going to stop that blade in a timely fashion - the distance from blade to brake is going to be almost one inch from it. But maybe I am just misunderstanding, and you are using the dado brake and have never changed the gap... Quote Link to comment Share on other sites More sharing options...
