hudsonoffice Posted June 11, 2012 Report Share Posted June 11, 2012 I have decided to build a chest of drawers awhile ago and now I am getting back to it. I have made my side panels of solid wood versus the plywood. So the question is where should I appy my glue on the webframes? Just on the front web where the legs meet or just the back or both front & back? And what about glue on center support? Quote Link to comment Share on other sites More sharing options...
thewoodwhisperer Posted June 11, 2012 Report Share Posted June 11, 2012 I would apply glue to the area you LEAST want to see movement. And the place where movement would be the biggest visual issue is at the front. So I'd probably apply glue to the front 3-4" and let the back float. As for the center support, can you clarify a bit? Quote Link to comment Share on other sites More sharing options...
CessnaPilotBarry Posted June 12, 2012 Report Share Posted June 12, 2012 In other words, where pieces align, either flush or with a reveal, and are seen and touched most, is the first choice for glue. As Mark wrote, most often the front. Remember... EVERYTHING that attaches to the sides needs to be glued in the same area, so the movement will happen where you want. If you glue the web frames at the front, do the same with moldings, tops, drawer guides and kickers, etc... It might be obvious, but I've seem pieces where folks glued moldings at the front corners, and guides at the back. Quote Link to comment Share on other sites More sharing options...
hudsonoffice Posted June 16, 2012 Author Report Share Posted June 16, 2012 Great answers gentlemen would expect nothing less from this forum. I will glue on the front. Mark, what i meant was should I apply glue also at the rear divider support "D"? Quote Link to comment Share on other sites More sharing options...
hudsonoffice Posted June 16, 2012 Author Report Share Posted June 16, 2012 Mark, When you say 3-4" in front I still do not want any glue on the center panel correct? Quote Link to comment Share on other sites More sharing options...
thewoodwhisperer Posted June 16, 2012 Report Share Posted June 16, 2012 Hey Hudson. I would NOT apply glue to the rear divider support. Just let the frames float in the grooves. Now when you say "center panel" are you referring to the back panel or the center of the side panel. Either way, no glue in either location. Quote Link to comment Share on other sites More sharing options...
Bobby Slack Posted June 17, 2012 Report Share Posted June 17, 2012 Great topic. I am building a web frame small entertainment center wit a deck, a mid shelf, top shelf plus table top. Will have pictures soon. All my joinery is done with dominos. the blades were going to be glued to the front and rear face frame but now I will not. Thank you. Quote Link to comment Share on other sites More sharing options...
