dcustoms Posted January 8, 2013 Report Share Posted January 8, 2013 Hello all! I just took on a job building a small kitchen in a commercial building. The plans call for an ADA compliant sink base. I know that counter height has to be 34" at the sink and I read the rules about clearances but having never built one I'm not sure on the exact design. The plans also call for a disposal so I have that to contend with. Any ideas, drawings, pictures or suggestions would be appreciated! Thanks, Quote Link to comment Share on other sites More sharing options...
dwacker Posted January 8, 2013 Report Share Posted January 8, 2013 ADA for commercial building dont use a sink base. They use a sink collar, a 30/60 base is not legal for commercial or governmental. 5.5" tall 24 deep. Don Quote Link to comment Share on other sites More sharing options...
duckkisser Posted January 8, 2013 Report Share Posted January 8, 2013 rules we dont need no stinken rules i say put the garbage and food prep on the same surface and store your chicken/red meat/ and fish all in the same container. and while were at it everything needs to be cooked with peanut oil. have fun dustin i hate cooking regulations there all so particular and exact. Quote Link to comment Share on other sites More sharing options...
dwacker Posted January 8, 2013 Report Share Posted January 8, 2013 rules we dont need no stinken rules i say put the garbage and food prep on the same surface and store your chicken/red meat/ and fish all in the same container. and while were at it everything needs to be cooked with peanut oil. have fun dustin i hate cooking regulations there all so particular and exact. Americans with disabilities act. Quote Link to comment Share on other sites More sharing options...
dwacker Posted January 8, 2013 Report Share Posted January 8, 2013 Your sink collar is just build to match. You usually have 5.5" to work with, actually 5" + - .5". Your 34 is is at the highest point either the very top of your sink bowl or drip edge which ever is higher. Your 24" is to the wall not the splash. You need counter sample and your offset sink bowl to draw out a plan. If you dont have access to these then build your collar box out of 3/4 ply but only 3.5 to 4" tall. Make your false front to match your cabinet work just a hair over 4". If its to tall you can just unscrew it. Think false drawer front. Your plumber will supply the low profile drain and disposal its not the cabinet builders issue. Your kick panel gets installed and made after the plumber has done his job. Don 1 Quote Link to comment Share on other sites More sharing options...
dcustoms Posted January 8, 2013 Author Report Share Posted January 8, 2013 Thanks Don I will talk to the GC and go about it that way. That is kind of what I was thinking but i wasn't sure and didn't want to get into a trick bag. thanks, Quote Link to comment Share on other sites More sharing options...
dwacker Posted January 8, 2013 Report Share Posted January 8, 2013 Also have the contractor or building owner sign off on your toe kicks. 6" tall is standard but some places require locally that you go 8.5" tall. Don Quote Link to comment Share on other sites More sharing options...
