Zack Snowy Posted January 31, 2014 Report Share Posted January 31, 2014 Hey guys, I am in the process of making a couple more end grain cutting boards. In the past I have always used Watco butcher block oil. In my opinion it seems to be getting the job done, but I have never tried anything else, and there are a lot of mixed opinions on it. I am hoping that one of you guys have tried other brands like general finishes and would be able to compare. Or maybe I am just being to cautious. I am not interested in using mineral oil or beeswax finishes. Quote Link to comment Share on other sites More sharing options...
Freddie Posted January 31, 2014 Report Share Posted January 31, 2014 I know of gf salad bowl finish, and I think tried and true oil is also non toxic, but I never used it so I am not sure. I love butcher block oil because of its crysal clear application. It shows the true beauty of the wood without tinting. A re-coat is always in order from time to time to maintain, but it is still a nice finish. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted January 31, 2014 Report Share Posted January 31, 2014 Only drawback to Watco Butcher Block oil is it has a bit too much varnish in it. If you re not careful it builds up on the surface, I found that out the hard way. Thin coats and rub it out , don't leave a thick coat. Quote Link to comment Share on other sites More sharing options...
Freddie Posted January 31, 2014 Report Share Posted January 31, 2014 Only drawback to Watco Butcher Block oil is it has a bit too much varnish in it. If you re not careful it builds up on the surface, I found that out the hard way. Thin coats and rub it out , don't leave a thick coat. I usually do three coats, each one is wiped of all the excess and periodically checked to wipe off any bleeding oil, usually never happens. Light sanding 600 between coats, never had a build problem yet, seems to work well. Quote Link to comment Share on other sites More sharing options...
Zack Snowy Posted January 31, 2014 Author Report Share Posted January 31, 2014 Do you guys thin your coats with mineral spirits? I know Marc does that with the gf finish, but on the watco label it says not to thin it. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted January 31, 2014 Report Share Posted January 31, 2014 I use it straight from the can. Apply it in thin coats and wipe off all the excess. Quote Link to comment Share on other sites More sharing options...
Luckypup Posted February 1, 2014 Report Share Posted February 1, 2014 I prefer to stick with the non toxic options when it comes to cutting boards or bowls. I have had really good results with Circa 1850 Naturoil. However it's more of a wood preservative because it doesn't form a film finish. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
rodger. Posted February 2, 2014 Report Share Posted February 2, 2014 I just use straight mineral oil from the pharmacy. Inexpensive, 100% food safe, and easy to apply. Quote Link to comment Share on other sites More sharing options...
Noah Posted October 23, 2022 Report Share Posted October 23, 2022 Hey so I’m using watch butcher block oil and finish also, I have done 3 coats so far and am debating on doing another but I wanted to ask if anyone knew if you NEED to sand it before you do another coat or if I can put another coat on without sanding… thanks for any help. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted October 24, 2022 Report Share Posted October 24, 2022 I would sand. Quote Link to comment Share on other sites More sharing options...
