Mike Corwin Posted May 9, 2014 Report Share Posted May 9, 2014 Hi all - Making 2 bookcases out of Cherry Plywood, and I'm using solid Cherry for the face frame and shelf fronts. The sides of the top and bottom pieces have cherry veneer tape to cover up the ply's as well. I usually work with walnut and use an oil/varnish blend but with the Cherry I realize that matching up the solid wood/plywood/veneer tape is gonna be extremely hard, let alone once the Cherry darkens over time. I would like to blend everything together as best as possible, which leads me to believe I should be using a stain. What do you all suggest? Sanding sealer, stain, oil/varnish? Would using a dye be better than a stain? Much appreciative for any help! - Michael Quote Link to comment Share on other sites More sharing options...
Trip Posted May 9, 2014 Report Share Posted May 9, 2014 If you have access to spray gear, I can give you an equalizer schedule developed for mixing solid Cherry stock and Cherry ply. But it uses alcohol dyes, so it's spray only... Quote Link to comment Share on other sites More sharing options...
Mike Corwin Posted May 9, 2014 Author Report Share Posted May 9, 2014 Thanks very much, however I don't have any spray equipment. Any tips on the difference between using a stain vs. dye in terms of masking irregularities? Quote Link to comment Share on other sites More sharing options...
Rick LoDico Posted May 9, 2014 Report Share Posted May 9, 2014 These cherry bookcases are made with cherry and cherry ply. I like to give cherry a coat of Watco Cherry Danish Oil which darkens and reddens both the solid and the ply fairly evenly followed by a few coats of Waterlox. This combo ages very well. The backs are luan ply and the color varies from the cherry. Quote Link to comment Share on other sites More sharing options...
Mike Corwin Posted May 9, 2014 Author Report Share Posted May 9, 2014 Rick, are you using any pre-stain conditioner or wash coat prior to applying the Danish Oil? Also, very impressive work! Quote Link to comment Share on other sites More sharing options...
Rick LoDico Posted May 9, 2014 Report Share Posted May 9, 2014 Mike, No wash coats. I've never had a problem with cherry blotching. Quote Link to comment Share on other sites More sharing options...
