Shane Jimerfield Posted February 28, 2015 Report Share Posted February 28, 2015 Your wall side stile should be made 1 1/2 to 2" wider. Back cut it so that the part that hangs off the cabinet is only 1/2 to 3/8 thick this makes it easy to run down the wall with a trim router. Most walls are off by quite abit. For the wall side that you did not make a built in scribe you would add a scribe with a long grain joint screwed, hiding the screws behind the hinges. So the wall is the guide? Now that it's in my brain it seems so obvious. Thanks. Sent from my KFTHWI using Tapatalk HD Quote Link to comment Share on other sites More sharing options...
Tom Cancelleri Posted February 28, 2015 Author Report Share Posted February 28, 2015 Yes, to scribe you can use a scribe tool that holds a pencil, a compass, or do it with a trim router and bit Quote Link to comment Share on other sites More sharing options...
Shane Jimerfield Posted February 28, 2015 Report Share Posted February 28, 2015 Hmmm...I thought that you push the cabinet close to the wall and put the router on the face. Then run it down with the edge of the plate against the wall. No? Am I totally confused? Quote Link to comment Share on other sites More sharing options...
dwacker Posted March 1, 2015 Report Share Posted March 1, 2015 Hmmm...I thought that you push the cabinet close to the wall and put the router on the face. Then run it down with the edge of the plate against the wall. No? Am I totally confused? Sort of you pull the cabinet away from the wall needed for your scribe base. Most installers use a offset base or a quick scribe. For quick scribe on a pc router its 1". Quote Link to comment Share on other sites More sharing options...
Shane Jimerfield Posted March 1, 2015 Report Share Posted March 1, 2015 got it. https://www.youtube.com/watch?v=skgjLAp0ODg&feature=channel&list=UL Quote Link to comment Share on other sites More sharing options...
Brendon_t Posted March 1, 2015 Report Share Posted March 1, 2015 That thing is pretty ninja. . Quote Link to comment Share on other sites More sharing options...
Tom Cancelleri Posted March 1, 2015 Author Report Share Posted March 1, 2015 That thing is the T and the A! Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted March 1, 2015 Report Share Posted March 1, 2015 That is cool. Quote Link to comment Share on other sites More sharing options...
