Niku Posted May 26, 2015 Report Posted May 26, 2015 I had a contractor replace the particle board in my kitchen floor with plywood. I hired a contractor because I wasn't confident that I could do the job. However, I now want to do the same thing in other parts of my mobile home, but I'd like to do it myself this time. My only concern is the spaces that will inevitably appear between the sheets/pieces of plywood. What material would be best for this? Plastic wood would probably do a good job, but I want something cheaper. Since my job will probably have more such spaces than a professional's job, I expect to have to do a lot of patching. What's good and not too expensive? Quote
Woodenskye Posted May 26, 2015 Report Posted May 26, 2015 Just butt joint them together and don't fill the gaps. Quote
Tom King Posted May 26, 2015 Report Posted May 26, 2015 No reason for gaps. Lay out the first row, and don't nail anything. Stagger the next row, and persuade both to fit perfectly. Once there, fasten down, and the next rows should fit perfectly. The trick is not to fasten down the first piece until it's abutting its neighbor.When you buy the plywood, select good pieces without beat up edges, and do what you have to getting it to the job without beating up the edges.We did such a plywood floor for a sail loft once. They didn't even want nails in it other than around the edges. Quote
..Kev Posted May 26, 2015 Report Posted May 26, 2015 Unless your gaps are huge, there's no reason to fill. Like Tom said, just plan it out. Measure twice and cut once. Quote
Dave H Posted May 26, 2015 Report Posted May 26, 2015 Fix All it's like a sheet rock hot mud once mixed apply expediently as it will set up in 5/10 min. they also make a feather patch it has a longer open time you can get that at a flooring store it's used by flooring installers to feather out areas that are going to get vinyl flooring Fix All is at home center HD or Lowes. I agree with tight joints on the original install but the way I'm reading this thread is he's already installed the plywood. Quote
trz Posted May 26, 2015 Report Posted May 26, 2015 If in fact you Do end up with gaps you want filled go to Hd and get some floor leveling compound. Quote
wtnhighlander Posted May 27, 2015 Report Posted May 27, 2015 Did you use standard plywood, or T&G subflooring? Quote
Jim DaddyO Posted May 27, 2015 Report Posted May 27, 2015 I too have a mobile home. If there is water damage, you want to get the particle board out from under the walls too (that can be a challenge). Replace the particle board with T&G plywood the same thickness of the original floor, the seams should line up over the joists. I found this site when I first got my home and it has a wealth of good information. http://mobilehomerepair.com/index.php Quote
Niku Posted May 27, 2015 Author Report Posted May 27, 2015 Just butt joint them together and don't fill the gaps. Easier said than done. Anyway, my question is about when there are large gaps betwen the sheets of plywood. Quote
Niku Posted May 27, 2015 Author Report Posted May 27, 2015 No reason for gaps. Lay out the first row, and don't nail anything. Stagger the next row, and persuade both to fit perfectly. Once there, fasten down, and the next rows should fit perfectly. The trick is not to fasten down the first piece until it's abutting its neighbor. When you buy the plywood, select good pieces without beat up edges, and do what you have to getting it to the job without beating up the edges. We did such a plywood floor for a sail loft once. They didn't even want nails in it other than around the edges. I don't want gaps, but sometimes I don't get what I want. My qustionn is what to do when gaps appear. Quote
Niku Posted May 27, 2015 Author Report Posted May 27, 2015 Unless your gaps are huge, there's no reason to fill. Like Tom said, just plan it out. Measure twice and cut once. Gaps can and will appear (it depends upon the skill of the one installing the sheets of plywood), and large gaps cannot be ignored. Installing linoleum over such gaps is asking for trouble. Quote
Niku Posted May 27, 2015 Author Report Posted May 27, 2015 Fix All it's like a sheet rock hot mud once mixed apply expediently as it will set up in 5/10 min. they also make a feather patch it has a longer open time you can get that at a flooring store it's used by flooring installers to feather out areas that are going to get vinyl flooring Fix All is at home center HD or Lowes. I agree with tight joints on the original install but the way I'm reading this thread is he's already installed the plywood. No, I'm talking about future plywood installation, and it sounds as if "Fix All" is not the product for large gaps. However, since I may have misunderstood your remarks, I'll ask about it the next time I go to Home Depot. Quote
Niku Posted May 27, 2015 Author Report Posted May 27, 2015 If in fact you Do end up with gaps you want filled go to Hd and get some floor leveling compound. That might be what I'm looking for. Now that you mention it, I remember once using it for floor leveling in the bathroom prior to toilet installation. I remember sanding it until the floor was perfectly level. Thanks, I think it will do the job. Quote
Niku Posted May 27, 2015 Author Report Posted May 27, 2015 Did you use standard plywood, or T&G subflooring? I don't know what T & G subflooring is, but I'll ask about it the next time I buy plywood. Is it stronger and more rigid than ordinary plywood? Quote
Niku Posted May 27, 2015 Author Report Posted May 27, 2015 I too have a mobile home. If there is water damage, you want to get the particle board out from under the walls too (that can be a challenge). Replace the particle board with T&G plywood the same thickness of the original floor, the seams should line up over the joists. I found this site when I first got my home and it has a wealth of good information. http://mobilehomerepair.com/index.php Seeing this second mention of T&G, I had to look it up. I now remember planning to use Tongue and Grove panels on a front porch deck. I didn't, and later regretted it. Anyway, although I presume that they would be more expensive, it doesnt seem to me that they would be any more rigid than ordinary plywood. Even so, if there is not a significant price differential, I would prefer using T&G panels. I've bookmarked the blink you supplied.. I may have purchased their book years ago but it could have been someone else. I'll look into it. Quote
trz Posted May 27, 2015 Report Posted May 27, 2015 http://www.dap.com/images/products/59184.jpg Quote
Jim DaddyO Posted May 27, 2015 Report Posted May 27, 2015 A floor levelling compound is too brittle. Mobile homes move. It does not matter if they are on frost line footings and anchored, they move. It is just the nature of the beast. So a cement type levelling compound will crack and peel away from the floor. You should not have cracks that are very big in the new floor, but if you do here are a few things I would keep in mind. If you are putting wall to wall carpet down, a good underlay material will help with a lot of them Click lock laminates will span small cracks too, again, get a good underlay for it as the house will move as stated and your floor will have gentle dips in it. If you want a vinyl floor, you may want to put a layer of 1/8" luan as an underlay. Cracks should not be more than 1/8" in the floor. If you are worried about them you can squeeze in some silicone of latex caulking as a "quick and dirty" remedy. You are taking a bit of a chance on this one though. I would cover the whole (new) floor with luan first. Quote
wtnhighlander Posted May 28, 2015 Report Posted May 28, 2015 T&G plywood subflooring is less likely to buckle at the edges, since they join together. Quote
