M Robertson Posted January 25, 2016 Report Share Posted January 25, 2016 For the guy who was asking on the podcast how to make an angled insert...check out Matthias Wandel's YouTube channel, he can help you out. I think the issue he was having has to do with the fact that you can't lower the blade far enough to not need to drop the insert on the spinning blade to get started. Bad idea if it is tilted! The secret is to install 7 1/4" blades to make the initial cut. Hope that helps! Quote Link to comment Share on other sites More sharing options...
Gary-ks Posted January 25, 2016 Report Share Posted January 25, 2016 Or just cut a shallow dado on the underside of the insert so the blade will clear when it is at the angle desired........... Quote Link to comment Share on other sites More sharing options...
Immortan D Posted January 25, 2016 Report Share Posted January 25, 2016 Just make sure the 7 1/4 blade has the same kerf of your table saw blade. I have a couple that don't (thin kerf blades). Quote Link to comment Share on other sites More sharing options...
Barron Posted January 25, 2016 Report Share Posted January 25, 2016 Depending on how large of cuts he is trying to make it might be simpler to build a crosscut sled. Just remember that the blade comes out the back of the sled at an angle so be careful where you place the screws to fasten the fence pieces. Don't ask how I know. Quote Link to comment Share on other sites More sharing options...
ColinF Posted January 25, 2016 Report Share Posted January 25, 2016 18 minutes ago, Barron said: Depending on how large of cuts he is trying to make it might be simpler to build a crosscut sled. Just remember that the blade comes out the back of the sled at an angle so be careful where you place the screws to fasten the fence pieces. Don't ask how I know. I bet that was exciting! Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted January 26, 2016 Report Share Posted January 26, 2016 Good reason to only use brass screws for saw jigs! 2 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted January 26, 2016 Report Share Posted January 26, 2016 If you build a cabinet for a MRI room you use brass screws too. Forgot about the screwdriver and the magnet tried to take it out of my hand ! 2 Quote Link to comment Share on other sites More sharing options...
Brian Noel Posted January 26, 2016 Report Share Posted January 26, 2016 That sounds fun, like something I would see on House. Good think you didn't have a metal pin in your leg. Quote Link to comment Share on other sites More sharing options...
mds2 Posted January 26, 2016 Report Share Posted January 26, 2016 12 hours ago, wtnhighlander said: Good reason to only use brass screws for saw jigs! I have never considered that until now. This is a really good idea. Quote Link to comment Share on other sites More sharing options...
