eric.l.mathison Posted September 26, 2016 Author Report Share Posted September 26, 2016 A card scraper needs a burr. You use a burnisher to create the burr. You use a file from time to time to flatten the edge and remove previous burrs. So you don't need a burr on any other tool? Quote Link to comment Share on other sites More sharing options...
Immortan D Posted September 26, 2016 Report Share Posted September 26, 2016 Only on scrapers as far as I know. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted September 27, 2016 Report Share Posted September 27, 2016 2 hours ago, eric.l.mathison said: So you don't need a burr on any other tool? The answer was only hinted at here. Card edges can groove your soft stones. This is the big reason to joint with a file. You can do it with a stone, but that cuts into efficiency when you need to dress the stone. The burr is because of the mechanics of usage. You do not shear cut the same as a knife edge will turned around the other way. You technically can get by without a burr if you have a sharp edge. Again, the burr is more capable and therefore more efficient. 1 Quote Link to comment Share on other sites More sharing options...
Immortan D Posted September 27, 2016 Report Share Posted September 27, 2016 You can skip the burr if the blade is thick enough to hold an edge. That's the case with scraping planes. But with card scrapers you cannot skip it unless you want to sharpen again every few passes. Quote Link to comment Share on other sites More sharing options...
eric.l.mathison Posted September 27, 2016 Author Report Share Posted September 27, 2016 The answer was only hinted at here. Card edges can groove your soft stones. This is the big reason to joint with a file. You can do it with a stone, but that cuts into efficiency when you need to dress the stone. The burr is because of the mechanics of usage. You do not shear cut the same as a knife edge will turned around the other way. You technically can get by without a burr if you have a sharp edge. Again, the burr is more capable and therefore more efficient. Ah thanks a bunch for clearing that up. Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
