collinb Posted October 19, 2016 Report Share Posted October 19, 2016 If you want this you will not be wanting it shipped. It's heavy. It's a Ridgid jointer. No. Not the one I just purchased. But it is the same model. The infeed side is shattered. Broken beyond repair. At least as far as I can figure. If you can weld and re-engineer. Then perhaps you can. So if you ever wanted to build a jointer now is your chance. And in this case you only need to build the infeed side. You get the base, the top including the broken parts. The motor and belt. All there. Just rebuild the infeed. Yes, it has the fence. First $100 gets it. (The 1hp motor is worth that.) PayPal accepted. Sent from my MotoE2(4G-LTE) using Tapatalk Link to comment Share on other sites More sharing options...
Llama Posted October 19, 2016 Report Share Posted October 19, 2016 Comes with twine? Link to comment Share on other sites More sharing options...
mat60 Posted October 19, 2016 Report Share Posted October 19, 2016 How did you end up with a broken jointer? Link to comment Share on other sites More sharing options...
collinb Posted October 20, 2016 Author Report Share Posted October 20, 2016 1 hour ago, Llama said: Comes with twine? Buyer's choice. 1 hour ago, mat60 said: How did you end up with a broken jointer? Thought I could fix the infeed. Overly optimistic. Link to comment Share on other sites More sharing options...
estesbubba Posted October 20, 2016 Report Share Posted October 20, 2016 $5 of JB Weld and it should be good to go. 1 Link to comment Share on other sites More sharing options...
wdwerker Posted October 20, 2016 Report Share Posted October 20, 2016 Parts ! Just find someone with a broke outfeed table ! 1 Link to comment Share on other sites More sharing options...
