Dolmetscher007 Posted January 11, 2017 Report Share Posted January 11, 2017 I have an opportunity to buy a very well maintained Bosch 4000 jobsite table saw. It was around $1,000 brand new, but I can buy it from a friend for $325. Now, I cannot stress enough two very important things. I am in desperate need of a table saw, but I am also on a very tight budget. I know that everyone says that; so much so it gets annoying. Everyone is on a tight budget, but everyone expects perfection from their tools. My question is... are jobsite table saws like this one simply garbage for furniture and precision cabinet making? If so, can someone give me a little information on what it is about them that sucks for shop work? If the problem is an inaccurate fence, what do you guys think about some of the videos you see about building an after-market high precision table saw fence? Quote Link to comment Share on other sites More sharing options...
4square Posted January 11, 2017 Report Share Posted January 11, 2017 In my opinion, the Bosch job site table saw is one of the best worksite saws money can buy. It is precisely what it says "A Jobsite Saw". For cabinet making and furniture making it will fall short. Reason #1 is lack of rip capacity. Reason # 2 not enough H/P to accommodate ripping or cross cutting hard woods of thickness' more than 3/4". I suppose you could build a cabinet to house the saw that would increase your rip capacity. But by the time you are done building the whole set up you could have bought a decent used contractors saw with a 2hp motor on Craig's list for about the same money. My advise would be patience and keep looking for a saw that will out perform your expectations. Quote Link to comment Share on other sites More sharing options...
Ronn W Posted January 11, 2017 Report Share Posted January 11, 2017 I work for about 3 years with a Ridgid foldable contractors saw and while it does limit your rip width I found that it did much of what I needed. Once set up square and true it was accurate enough for tenons, lap joints, etcs. The miter gauge on most contractor saws are "iffy" when it comes to repeatable square cuts because they fit sloppily into the miter slot. I solved that by building a cross cut sled, a miter sled for picture frames and a dado blade sled. I will admit that I checked my setup more often and made test cuts more often than I do with a better saw but, in the end it served my well. Just make sure that it is in good condition and try to test it before buying (take apiece of wood with you). If the saw is decent you can probably sell it later for the saw price when you can afford an upgrade. We work with what we have. Good luck making saw dust. Quote Link to comment Share on other sites More sharing options...
Dolmetscher007 Posted January 11, 2017 Author Report Share Posted January 11, 2017 16 minutes ago, 4square said: Reason #1 is lack of rip capacity. Reason # 2 not enough H/P to accommodate ripping or cross cutting hard woods of thickness' more than 3/4". The Bosch 4000 has a 4.5 HP motor. And I would definitely build an enclosure for the saw. Quote Link to comment Share on other sites More sharing options...
Isaac Posted January 11, 2017 Report Share Posted January 11, 2017 13 minutes ago, Dolmetscher007 said: The Bosch 4000 has a 4.5 HP motor. And I would definitely build an enclosure for the saw. Im no expert, but I don't believe that little saw has 4.4hp the same way big cabinet saws do...something is very fishy. 2 Quote Link to comment Share on other sites More sharing options...
Spencer_J Posted January 11, 2017 Report Share Posted January 11, 2017 10 minutes ago, Dolmetscher007 said: The Bosch 4000 has a 4.5 HP motor. And I would definitely build an enclosure for the saw. there is a magnificent difference between a 15 amp 120v motor (which is what the bosch 4000 has) and a 20 amp 220v motor which comes with your standard cabinet saw. I'm not quick enough with the proper specifications on how to qualify horsepower so i wont comment on what is deemed horsepower. If you're only doing hobby woodworking and plan to do some smaller furniture projects maybe a bathroom vanity or shop cabinets i'd say do the deal with your buddy and learn everything there is to know about owning a higher quality job site saw. i had a fine little ryobi for a few years before i could come up with the money for a used cabinet saw. I melted the gears resawing 3" hard maple running a 3/32 diablo blade. i was in the middle of a big project and had to tell my client that it was going to be another month before their cabinet was done and they wanted their money back due to time constraints. i wish i had bought a belt driven contractor saw instead. now that i own a unisaw, i should have just got the unisaw in the first place but i wouldn't know half of the tricks i learned on that little ryobi. good luck! 1 Quote Link to comment Share on other sites More sharing options...
Mark J Posted January 11, 2017 Report Share Posted January 11, 2017 59 minutes ago, Spencer_J said: there is a magnificent difference between a 15 amp 120v motor (which is what the bosch 4000 has) and a 20 amp 220v motor which comes with your standard cabinet saw. I'm not quick enough with the proper specifications on how to qualify horsepower so i wont comment on what is deemed horsepower. Power is equal to volts x amps. So 20 amps at 240 volts is about 2.6 times the power of 15 amps at 120 volts. I think one horsepower is 750 watts. 1 Quote Link to comment Share on other sites More sharing options...
Isaac Posted January 11, 2017 Report Share Posted January 11, 2017 12 minutes ago, Mark J said: Power is equal to volts x amps. So 20 amps at 240 volts is about 2.6 times the power of 15 amps at 120 volts. I think one horsepower is 750 watts. And a saw that requires a 15 amp, 120 circuit doesn't necessarily draw all 15 of those amps. Most likely it uses at most about 12 amps. 1 Quote Link to comment Share on other sites More sharing options...
davewyo Posted January 11, 2017 Report Share Posted January 11, 2017 I used a DeWalt jobsite saw for a few years. It would cut 8/4 hardwoods if I took my time. It held it's adjustments pretty darned well. Dust collection was good. I did quite a few projects with it before I upgraded. Quote Link to comment Share on other sites More sharing options...
Unknown craftsman Posted January 11, 2017 Report Share Posted January 11, 2017 That's a very good portable saw I had one for several years. I put a thin kerf woodworker 2 blade on it and it did everything I wanted. The fence is not as good as my cabinet saw but I used to it. I say go for it. Aj Quote Link to comment Share on other sites More sharing options...
Isaac Posted January 12, 2017 Report Share Posted January 12, 2017 Despite my comments about the power, I have a sawstop jobsite saw, it satisfied my desire for something portable, cost, my power limitations, and my wife's requirement that it have the sawstop safety feature. it is a good saw, but does have limitations, particularly in the power department, but I've learned to deal with it. It would be a lie to suggest my table saw is a major determining factor in the quality of my projects. Quote Link to comment Share on other sites More sharing options...
