pridmore Posted February 9, 2017 Report Share Posted February 9, 2017 I did a quick, cursory search on this but didn't see exactly what I was looking for, so here goes... I have a the cheap HF dust collector with a super dust deputy dumping into a 55 gallon plastic barrel. I currently have it mounted to a thrown-together cart that gets in the way and takes up too much space (my shop occupies 2/3 of my 3 car garage, or as I like to tell my wife: her car occupies 1/3 of my shop). The cart takes up about a 4' x 3' footprint. If I mount the fan, dust deputy, and barrel vertically on the wall and jettison the plastic collection bag and crappy filter bag I can reduce the footprint to 2' x 2'.I have about 27" between the outer wall of my garage and the door rails/opening to my single garage door. That outside wall has a window about 3' from the proposed mounting location where I could vent the "fines" directly outside. The potential issue is that this window is at the front of the house. I can handle the "unsightliness" by designing a removable fixture to remove when I'm not in the shop. My question is this: will the resulting dust make a mess that a quick once-over with the leaf blower can't clean up? If anybody has experience with this, please chime in. Any other comments and opinions are welcome as well. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted February 9, 2017 Report Share Posted February 9, 2017 If your cyclone is working properly, you should barely notice any dust blowing outside. Quote Link to comment Share on other sites More sharing options...
mds2 Posted February 9, 2017 Report Share Posted February 9, 2017 If you have a heated garage your biggest problem is going to be blowing all your heat out the side of your house in the winter. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2017 Report Share Posted February 9, 2017 Just now, mds2 said: If you have a heated garage your biggest problem is going to be blowing all your heat out the side of your house in the winter. I really think that risk is overstated. Unless you are running your DC for hours on end, it will only have a marginal impact. Most of us only run the DC for a few minutes at a time while we are running a machine. I keep my heat at 55, even if an overhead door is open for 20 minutes and it is 0F outside, I get back up to temp quickly and I don't even notice the difference on my gas bill. Quote Link to comment Share on other sites More sharing options...
pridmore Posted February 9, 2017 Author Report Share Posted February 9, 2017 Thanks for the help, folks. It sounds like it could be a go. Quote Link to comment Share on other sites More sharing options...
mds2 Posted February 9, 2017 Report Share Posted February 9, 2017 18 minutes ago, Mike. said: I really think that risk is overstated. Unless you are running your DC for hours on end, it will only have a marginal impact. Most of us only run the DC for a few minutes at a time while we are running a machine. I keep my heat at 55, even if an overhead door is open for 20 minutes and it is 0F outside, I get back up to temp quickly and I don't even notice the difference on my gas bill. I tend to agree with you. I just see people bring it up when talking about venting outside and it is something to consider. I actually just moved into a new shop and I plan on venting outside too. Quote Link to comment Share on other sites More sharing options...
Popular Post Just Bob Posted February 9, 2017 Popular Post Report Share Posted February 9, 2017 4 hours ago, pridmore said: If anybody has experience with this, please chime in. Any other comments and opinions are welcome as well. I have the HF unit/SSD and vent outside. The only time I have seen visible dust is when I stick a hose into a big pile of sawdust and even then the dust cloud is very thin and dissipates immediately. My reasons for doing this are the same as yours, I hated the space the mobile unit took up. Here is a pic. 3 Quote Link to comment Share on other sites More sharing options...
pridmore Posted February 10, 2017 Author Report Share Posted February 10, 2017 8 hours ago, Just Bob said: I have the HF unit/SSD and vent outside. The only time I have seen visible dust is when I stick a hose into a big pile of sawdust and even then the dust cloud is very thin and dissipates immediately. My reasons for doing this are the same as yours, I hated the space the mobile unit took up. Here is a pic. Thank you! Thanks what I was hoping to hear Quote Link to comment Share on other sites More sharing options...
