drzaius Posted June 1, 2017 Report Share Posted June 1, 2017 That's gonna be a great looking door. There is a stained glass project or two in my future and I'm looking forward to learning that. Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 1, 2017 Author Report Share Posted June 1, 2017 The door would have been very cool. Adding the shop made stained glass is going to kick it into a totally different level of awesome. I really like that though out your builds, it seems like you are constantly pushing yourself and trying new and interesting things. Keep it up Brad. It is kind of funny you say that. Before I started, I got a little bit nervous like the first time you use a power tool. Maybe it is the adrenaline I am always chasing. Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 1, 2017 Author Report Share Posted June 1, 2017 Looks awesome. I'm gonna have to go ahead and ask you to drop everything and finish that stained glass ASAP so I can see the finished product. Ok? You are in for some good news because I am going to be working on this non stop. Throughout the year I have also been remodeling a house. That took up a lot of my time. I just put it on the market on Monday, so it is all woodworking from now on. My next project is a table build. It is going to be pretty sweet too. 2 Quote Link to comment Share on other sites More sharing options...
bgreenb Posted June 1, 2017 Report Share Posted June 1, 2017 12 minutes ago, bradpotts said: Throughout the year I have also been remodeling a house. That took up a lot of my time. I sympathize Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 1, 2017 Author Report Share Posted June 1, 2017 I will try to give you a step by step here. I use the lead shears to cut out the pattern. I cut a strip of glass. then I use running pliers to break it. then I trace the pattern on the glass. Cut the glass. I use grozer pliers to break those cuts. For the smaller cuts I use a square. if anything needs cleaned up. I use this grinder. it is basically a sander for glass. Because the glass doesn't break perfectly it comes in really handy. I wouldn't do this without one. Then I mark where the lead is going to go. cut the lead with lead snips. Make sure not to cut down on the lead because you bend everything up. Then wrap the lead around and cut it to fit. Progress. 2 Quote Link to comment Share on other sites More sharing options...
drzaius Posted June 1, 2017 Report Share Posted June 1, 2017 14 minutes ago, bradpotts said: I use this grinder. it is basically a sander for glass. How well does the grinder do with regards to chipping. I've ground glass edges with a spindle sander, but found that the heat would cause some pretty significant chipping on the edges. Is it a diamond abrasive? Quote Link to comment Share on other sites More sharing options...
pkinneb Posted June 1, 2017 Report Share Posted June 1, 2017 Looks great Brad! The only tip I would add for those thinking of giving this a try would be using two patterns one for cutting the glass and the other taped to your board. It helps keep things straight and makes sure you get all the pieces in the right spot. If you get off it will show up right away. Quote Link to comment Share on other sites More sharing options...
pkinneb Posted June 1, 2017 Report Share Posted June 1, 2017 21 minutes ago, drzaius said: How well does the grinder do with regards to chipping. I've ground glass edges with a spindle sander, but found that the heat would cause some pretty significant chipping on the edges. Is it a diamond abrasive? The ones I have used work very well. Yes they are diamond abrasive and are wet grinders as well. Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 1, 2017 Author Report Share Posted June 1, 2017 Looks great Brad! The only tip I would add for those thinking of giving this a try would be using two patterns one for cutting the glass and the other taped to your board. It helps keep things straight and makes sure you get all the pieces in the right spot. If you get off it will show up right away. I thought about that but I didn't know how to account for the width of the lead. So I just made a boarder to make sure I stay inside. 1 Quote Link to comment Share on other sites More sharing options...
pkinneb Posted June 1, 2017 Report Share Posted June 1, 2017 1 hour ago, bradpotts said: I thought about that but I didn't know how to account for the width of the lead. So I just made a boarder to make sure I stay inside. I pretty much center it on the line. I have the colors marked in bold so I do not get the wrong color in the wrong spot...not that it has ever happened to me LOL 1 Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 1, 2017 Author Report Share Posted June 1, 2017 One down two to go! 2 Quote Link to comment Share on other sites More sharing options...
Alan G Posted June 1, 2017 Report Share Posted June 1, 2017 Wow! Looks amazing!!! I really like that blue glass. Deep rich color. 1 Quote Link to comment Share on other sites More sharing options...
pkinneb Posted June 2, 2017 Report Share Posted June 2, 2017 That looks great Brad awesome use of colors and curves! 1 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted June 2, 2017 Report Share Posted June 2, 2017 So how do you sign & date a window ? 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted June 2, 2017 Report Share Posted June 2, 2017 Looking awesome, Brad! 1 Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 3, 2017 Author Report Share Posted June 3, 2017 Got the glass soldered. and a preview . I did make a mistake. I changed the direction of the texture of the glass on the first round piece. 2 Quote Link to comment Share on other sites More sharing options...
davewyo Posted June 3, 2017 Report Share Posted June 3, 2017 10 minutes ago, bradpotts said: I did make a mistake. I changed the direction of the texture of the glass on the first round piece. It looks great, mistake or no... Can it be partially un-soldered and re done without a complete do-over? Quote Link to comment Share on other sites More sharing options...
Alan G Posted June 3, 2017 Report Share Posted June 3, 2017 It looks great! 1 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted June 3, 2017 Report Share Posted June 3, 2017 Repeat the reversal on the other panels and call it a feature ! Looking Good ! 2 Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 3, 2017 Author Report Share Posted June 3, 2017 It looks great, mistake or no... Can it be partially un-soldered and re done without a complete do-over? I don't know how hard it would be but as far as I am, I don't feel comfortable taking it back apart. Repeat the reversal on the other panels and call it a feature ! Looking Good ! Good point Steve. This way I will always know mine from the knockoffs! 1 Quote Link to comment Share on other sites More sharing options...
pkinneb Posted June 3, 2017 Report Share Posted June 3, 2017 Turned out great Brad!! I think you would do more damage than good trying to redue it given where the panel is at in the solder process. I agree with Steve just match the other two or at least the two outer panels, only you will ever know 1 Quote Link to comment Share on other sites More sharing options...
Tpt life Posted June 3, 2017 Report Share Posted June 3, 2017 I would rethink that plan. Typically, texture is inside as it is a bit more difficult to clean. Whoever cleans the door may not appreciate the panels being flipped. Quote Link to comment Share on other sites More sharing options...
James Miller Posted June 4, 2017 Report Share Posted June 4, 2017 This is amazing! Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Coop Posted June 4, 2017 Report Share Posted June 4, 2017 On 6/1/2017 at 7:51 PM, wdwerker said: So how do you sign & date a window ? It would be cool if he could work his inlaid plane into it. 1 Quote Link to comment Share on other sites More sharing options...
bradpotts Posted June 4, 2017 Author Report Share Posted June 4, 2017 It would be cool if he could work his inlaid plane into it. That is another reason above all the main reasons I hate stain. It is really difficult to put my plane in stained wood. Quote Link to comment Share on other sites More sharing options...
